NOTE: The VLPF uses the same five pin connections and orientation as the -EXG. The passive treble roll off has both block connectors the same way up.
the new one is like an amp with the treble and presence all the way up
I think it would need tweaking like a normal tone control
I had some steinbergers with active bass and treble EQ, which is easier to use.
I had the same pots installed on another strat , so know how it feels to tweak bass and treble independently
Either way, you may be underwhelmed. At least, you will have avoided mangling a pickguard.
