Our chimney stack is on the outside of the flat outer wall, and the roof slopes down to meet it at gutter level
So inside the bedroom below it, there is no chimney breast, and we keep getting water stains coming through into the wall and ceiling below where the chimney is
That inner wall effectively carries on up through the tiled roof and becomes the outside of the chimney, facing towards the roof tiles above the bedroom
Looking in the loft, the course of bricks are visibly water stained, clearly water has leaked down leaching salts and minerals over decades. The visible brick course either side (which do not carry on past the roof tiles) are clean and look recently laid (it was built around 1920). These are normal 1920 bricks, not the exterior shiny engineering kind
We had a roofer up there fixing this a few times, most recently with scaffolding. He's a good roofer, and he has fixed the tiles and flashing. The roof is heavy old tiles on top of a full wooden roof, not just rafters. There is no felt or tarpaulin-type lining under the slate tiles. I wondered if water was sometimes being blown up under the tiles and dripping down.
Anyway, it was fixed in Feb/March, repainted, and we've had a few stains reappearing over the last month
I put a long cardboard sheet under the roof in the loft, and there is no sign of water dripping down from the slates
The only causes I can think of are: leaking at the flashing - but as I say - recently fixed by very good roofer, or water seeping down through the bricks. The roofer checked the pointing, and they are Accrington-type engineering bricks outside, so in very good condition. The chimney is tall and wide, and is capped.
I'm thinking I should have DPC injections into the stained bricks in the loft
Does anyone have any experience / advice?
Turned out to be a condensation issue due to the chimney stack being capped off, thus leaving nowhere for moisture to ventilate.
This site covers it & it saves me typing
https://www.londondampcompany.co.uk/chimney-damp-the-common-damp-problem-youve-never-heard-of/
wall . You can get plaster board that is made for damp conditions . If this all sound a bit too much, you can paint a barrier on the wall . It actuly works better than it sounds , but it is not a permanent fix
we had the stack repointed fully about 5 years ago, and it is capped, and there is a vent in that room, so not sure it's a ventilation issue
Capped at top and a single vent in a breast actually does very little as you need good cross flow of air ;capping at top should also have some ventilation in it for airflow.
How many flues in the stack ?
This house is 100 years old, there was no normal DPC on the ground floor, it has some amazing weird electrical DPC fitted now that uses platinum electrodes
https://www.platinumchemicals.co.uk/products/lectros-electro-osmosis-damp-proofing-kit
Do you mean condensation from the air in the room onto the cooler plaster and brickwork?
Trouble is the council removed permitted development rights for our house, I'm going to try to get them back
Mind you it's a massive chimney stack, and there are 2 others, one of which is twice the size
We had proper leaks last year on one stack, there was clear water running down the wall, and the roofer fixed the leaks as far as we know, so I'm hoping we have eliminated the leaky roof possibility
https://www.heritage-house.org/damp-and-condensation/all-about-the-pca/the-damp-con-collection/electro-osmosis-damp-proofing-systems-an-expensive-fraud.html
http://dampbuster.co.uk/electro_osmosis.shtml
YMMV...
We have no damp anywhere in the ground floor AFAIK, been here 8 years, and done lots of work so would have seen it
The house was renovated by a building company who used it as an office in the 80s, I assume they fitted this system
Who knew that everything you once thought you knew, could be so confusing?
Still, every day's a schoolday... once the headaches cease.
Rainwater can get in in a number of ways. Soakers and flashings have a lifespan of about 80 years. Replacing one and not the other is foolish. Code 5 lead minimum for these. Some roofers/builders use Flashband as a bodge. Won't last.
Flaunching around the pots or cap can crack with age and let rainwater in. Driving rain can get into poor mortar joints . Solution is to redo the flaunching completely, not just fill the cracks.
When we did my son's roof last year we took the stack down to below roof level , might be the best solution if you're not using the flues and you think it might be rain getting in.
