Rack case recommendations please
I'm going for the optimistic approach for 2021 and racking up my gear ready for some live work, only problem is I don't have any road proof rack cases so...
What do y'all recommend?  Sturdy, water resistant and value for money recommendations would be most welcome.
'Vot eva happened to the Transylvanian Tvist?'
  • maltingsaudiomaltingsaudio Frets: 3115
    edited December 2020
    If your touring don’t bother with anything plastic, I would suggest Swan Flight or have a look at Scott Dixon. Nb secondhand is a good way to go
    www.maltingsaudio.co.uk
  • If your touring don’t bother with anything plastic, I would suggest Swan Flight or have a look at Scott Dixon
    On it with seasonal thanks :)
  • John_AJohn_A Frets: 3775
    How big do you need Paul, got a 3U Gator one not doing anything, a nice depth for a JMP-1 (if you ever need another you know where it is) and a Trojan shallow 3U as well (JMP-1 fits put sticks out the back, I used it for my GSP1101 and it is great for stuff like that
  • If your touring don’t bother with anything plastic, I would suggest Swan Flight or have a look at Scott Dixon. Nb secondhand is a good way to go
    ^ This Swan or Castle cases - if it's going to be getting transported in a van get a shock rack, they are not much more and will save a fair amount of wear to your kit.
  • I use the SKB shallow ones for my Kemper.
  • Thanks all. Yes, shock-racks are necessary, might have a mooch on the ‘bay. Going to need 2 x 10u and 2 x 8u.
    How big are these gigs!
    Big racks always pop up on eBay for not a lot of money
  • ESBlondeESBlonde Frets: 3581
    There is a flight case warehouse on line that will customers make, they also have used stock which will save a fortune. Ask on here and live sound web for exactly what you need, I dare say there is some quality used kit available right now.
  • phil_bphil_b Frets: 2010
    not true. the military use plastic  rack cases for portable comms equipment and they are solid (but also expensive)
  • FarleyUKFarleyUK Frets: 2382
    I use a gator 3u shallow one for my Axe FX3. Seems great so far!
