Audiostorm HotBox attenuators?
Tadragh1Tadragh1 Frets: 70
I've been searching for an attenuator recently and this came up:
https://www.seanmandrake.com/Products/HB125.aspx
I've seen the unfavourable reviews for one of their lower models on this forum years ago, but this device seems to be quite different. Three ways of attenuation to choose from: 2 inductive and 1 resistive. Seems like a win. Any experiences?
  • ecc83ecc83 Frets: 1589
    Construction is a bit 'kitchen table' but then not a bad price if it really will handle 125 watts. I think they missed a trick though in not providing a headphone/recording output?
    Dave.
  • Dave8Dave8 Frets: 241
    I’ve got their 60w version and it does what it says on the tin.
  • I mostly need it to knock a few dB off my Deluxe Reverb Reissue head and be able to hook up two 8 Ohm cabs at the same time.
  • Vintage-TVintage-T Frets: 405
    Did you get one of these in the end? I’ve come across them searching for a 4ohm attenuator. Thoughts if you did?
  • Tadragh1Tadragh1 Frets: 70
    Got a Weber MASS here at the forum instead.
