5v to 240v adapter/ power supply
I would like to convert a pc fun to 240v , so I can just plug it to a wall socket .
Ideally with the on/off switch if that's possible .
Is there a power supply adapter that would connect straight to the fan?
Connections are either 2/3 pin or usb ( this an extension that plugs into 2/3 pin like on the second picture ) .
  • maltingsaudiomaltingsaudio Frets: 3115
    edited January 2021
    Any low voltage dc adaptor which gives 5volts should do the job, with the right connector. Or just change the connector working out which wire plus the common spins the fan the right way. Actually just reading your post again, just use a phone charger which accepts USB and just plug the fan into it
    www.maltingsaudio.co.uk
  • JazzthatJazzthat Frets: 163
    Is it really as simple as using mobile phone charger ? That would definitely be simplest solution .
    I'll try tomorrow , thanks.
  • Should be,
  • How did you get on?
    How did you get on?
    Yeah ,all sorted  . I am using mobile phone charger and it has been ok since   .
