Hi, my band are looking to upgrade our PA - we’ve been using an old Yamaha system and I’m after some advice.
We’re a covers/function band with a drummer who can hit bloody hard, but can also control himself - we play clubs, events, weddings and sometimes pubs. When we’re not using an in-house or provided PA our Yamaha is a little rough and indistinct, and underpowered at 250w/speaker.
So, requirements - powerful female lead vocals and one backup male vocal, and some guitar line-out DI’d in for balance and spread are the essentials.
We are not blessed with a huge budget (around £650) - my wife (singer) and I are buying and we have 2 young kids so are not hugely flush at the moment.
For me the best option so far are the Alto TS312 or 315 powered speakers for FOH with a small mixer and the potential of adding a sub later. We have monitors.
So, questions:
1) would you recommend a 12 or 15 inch speaker for vocals with a hint of guitar? I wasn’t hugely keen on the 15s we used to have for vocals.
2) If we go with 12s, is it worth getting a sub so we could also stick the kick/bass player through it for spread?
3) if we go with 15s, would they effectively allow us that possibility of adding bass/kick without a sub without muddying everything else?
4) Any experience with the Altos? They seem to have good reviews and warranty, but I’m very much open to ideas on other brands/setups.
Thanks in advance. You can hear the band here if it helps:
www.soundcloud.com/undercovercoversband
Id also recommended RCF 710’s. A sub could be added later if you felt it was lacking for bigger gigs, or if you start mixing drums
The 12's are more robust but again need to be kept well within their limits. The HF driver blows quite easy which frankly is bad design as the whole point of active speakers is the internal amplifiers have a processed power output rather than flat response to protect their driver. These are available and not that expensive though.
I think there's an OEM in china that makes a lot of these low end active speakers for Alto and EV because I've seen some that were nearly identical when we fixed a batch of them for a PA hire company.
I know modern class D lightweight speakers is what bands think they should go for these days but in all honestly for the same money you could get a power amp like a PV2600 or similar and a set of robust passive speakers. Be a lot more robust and reliable.
I’ve also found a reasonably priced set of RCF710a speakers online but in all honesty haven’t even considered 10s!
https://www.ebay.co.uk/itm/HK-Audio-Premium-Pro-15X-Passive-speakers-PAIR/254802304720?hash=item3b53669ed0:g:8hUAAOSwnEFfz6-o
Electrovoice SX300 PA Speakers Used | eBay
SX300 would do the job nicely but would be better with a sub.
I am very happy with our 12” Altos. Plenty loud and clear. Done 3 solid years before lockdown.. not a hint of a problem (touch wood). Indoors, outdoors, marquees, etc.
Sometimes we put a Roland eDrum kit through. Handles those transients fine. Rarely need to use more than half power on the dial.
They will sound amazing compared to anything at double the price.
Check the online reviews from the pros.
We run two 18" subs with 12" tops and the sound is brilliant.
Most bands also don't tend to get the best out of their PA speakers because they either don't have the necessary knowledge or they only have a primitive desk with very basic EQ and no compression. If you remove all the crap the speaker can't reproduce and get the dynamics under control it makes a world a difference both in the sound and the longevity of the speaker.
The myth is the bigger the speaker the better the bass response which is partly true but it is mostly down to cabinet design. As Danny says “ If you remove all the crap the speaker can't reproduce and get the dynamics under control it makes a world a difference both in the sound and the longevity of the speaker. ”
With modern systems and more precise crossover cutoffs you might be able to get around that, but I'm not sure - personally I would always use subs for anything other than vocal/guitar mixes.
I tend to think of pa as sound reinforcement, in other words it amplifies your sound, but doesn’t create your sound.
