https://manchesterguitartech.co.uk/nitrocellulose-lacquer/lacquer-faqs/#satin
If you work a matte finish it won’t be matte anymore. Scuff down your orange peel surface with 360 or 400 (there abouts, only you can judge) and mist on a final clear coat then leave it alone. Any extra work there after will turn it satin which you don’t want.
Or, leave it as it is and continue with assembly
• Youtube - https://www.youtube.com/@Goldeneraguitars
To add to the above comments, Ive recently finished my first satin finish, and on Steve Robinsons' advice, I sprayed the final few coats in ordinary gloss clear. Once cured, flatted that off to leave a consistent surface, and a final coat of satin. Worked a charm![:) :)](/plugins/EmojiExtender/emoji/fb/1.gif)
Adam
https://i.imgur.com/8Ii0UcZ.jpg
As with most paints, with the right prep your next coat should always be a big improvement
Maybe I'll do a better job if I ever do this again.
