I’ve now got a dedicated room for a studio, redecorated, decent (big!) desk and all wired in - but it needs some acoustic treatment. It’s quite small, just under 3m each side, with a short section of sloping ceiling at the far end. As it’s so small, the desk is far closer to the wall than I’d like, although in reality it’s not as bad as it looks as the monitors are at the front edge of the shelf that curves away from the wall.
https://i.imgur.com/9kzR6cT.jpg
I’m thinking some panels on the wall behind the monitors and at the mirror points on the opposite wall for a start. I’m not too worried about bass traps (the sofa bed will help I guess), but I think cutting down on the reflections would be a good start.
Foam panels or the fabric covered frames? Bit of both? Would the sloping part of the ceiling be a problem or actually help in dispersing reflections?
But being realistic you can put some diffusion here and there to tame reflections but it's too small to bass trap without reducing the size dramatically.
You can still do great work in there, just keep the volume moderate and triple check the mixes in other spaces and environments.
Treat the mirror points (walls and ceiling) but also consider going across the corners if possible.
https://www.thefretboard.co.uk/discussion/192149/acoustic-panels#latest
To get a room completely under control of that size means more bass trapping than there is actual room for so I wouldn't go mad.
https://www.therange.co.uk/home-furnishings/picture-frames-and-wall-art/posters-prints-and-visual-artwork/canvas-art/white-and-soft-pink-embellished-poppies-canvas/#149410
https://www.thefretboard.co.uk/discussion/183659/acoustic-treatment-in-home-studio-let-the-fun-begin/p1
Loads of the great and the good chipped in with superb advice.
With decent foam or rockwool you can get almost as good results with 50mm thickness as you can with 100mm thickness by mounting the 50mm with a 50mm air gap to the wall.
The way sound travels, vibrating particles of air, means that as the particle approaches the hard surface behind the panel, it starts to slow down. When it hits the wall, it stops momentarily, losing a small amount of energy, and then accelerates away again. Think of it like a tennis ball. When the pressure is at s maximum the velocity is at a minimum/ when the velocity is at a maximum the pressure is at a minimum.
Porous absorbers work by absorbing energy from the particles and turning it into heat. This absorption is dependent on the velocity of the particles , not the pressure. So as the particles are not traveling as fast when near to the wall you do not get as much effect in that part of an absorbing panel. This is even more evident in corners of rooms where the sound pressure is high but the velocity low. So it's not worth filling corners, you just need panels across them.
For ceilings you can suspend a 50mm panel with an air gap of 50mm or 100mm and get a lot more performance. I usually use self tapping eyes hand screwed into metal plasterboard driver fixings and then a small wire rope with a loop on it threaded through an eye it bracket on the panel with a wire rope adjustable clutch to secure it. To get a perfect drop from the ceiling I cut a small piece of timber the size of the drop and hold it vertically between the ceiling and panel while I adjust the rope. For heavier panels I use expanding plasterboard fixings for the ceiling and small angle brackets. To set out on the ceiling you can set out on the ground and then 'plumb' the line or point up using a cross hair laser. Or you can cut out corrugated cardboard with to the size of the 4 points you need and hold that on the ceiling and mark it.
Of course, with properly thicker absorbers you get more absorption on waves that travel obliquely to the surface of the panels but as you can afford more coverage you can often still end up with more absorption overall.
Don't confuse absorption with diffusion, absorption reduces and diffusion scatters. You can achieve both by mounting many smaller absorbers with gaps of bare wall between them. The time delay this causes gives you diffusion as well as absorption.
Happy to answer any questions anyone has as and when I get a chance to answer.
https://i.imgur.com/Nb2jHek.jpg
