How to use Nut slot files? Recommendations please
ToneControlToneControl Frets: 11928
edited February 2021 in Making & Modding
I want to start tweaking my cheaper electric guitars
Does anyone know which sets to buy?
There are so many different ones on amazon
Edit: I bought some StewMac ones
Now I need to learn how to use them
  • PhilKingPhilKing Frets: 1481
    My original set, which I used for years, were Ibanez branded and had 3 double sided nut files and 3 double sided fret files.  I got them when I attended a guitar repair course with Stephen Delft in the 70's, so I'm sure that the exact set doesn't exist, but the nut files looked just like this, which I can find in a search online https://www.ebay.com/itm/264924302309?mkevt=1&mkcid=28&chn=ps
    Item won’t be sent to the UK...
  • ToneControlToneControl Frets: 11928
    @ICBM can you advise please?
  • PeteCPeteC Frets: 409
    Ive been very pleased with a set of hosco.    Pricey but a good investment
    I think I will have to pay for decent ones, can't see anything cheaper that looks convincing
  • PrecisionGuidedPrecisionGuided Frets: 72
    The decent ones are all expensive. The cheap ones may look similar but are rubbish.
    Best I've used are the Japanese  UO-Chikyu - HiroshimaNutfile
    Nine files  0.010 inch, 0.013 inch, 0.017 inch, 0.026 inch, 0.036 inch, 0.046 inch
    0.067 inch; 0.087 inch, 0.106 inch cover guitar and bass4 and cost approx £140
    So not worth buying for a single nut tweak, but essential if doing a lot of fettling.
    The StewMac diamond ones look very good too.
  • WhistlerWhistler Frets: 322
    I started off with 6 from StewMac and then bought other sizes as other guitars needed them. You are likely to have nut files for life so I wouldn't worry too much about the cost when you think of how often a new set of strings is needed, just to use one example.
  • Devil#20Devil#20 Frets: 1943
    If you know somebody with a Stu Mac account then tack on an order for some from them next time they order something.
    Ian
  • FelineGuitarsFelineGuitars Frets: 11599
    Hosco tapered electric guitar set would do it
  • JazzthatJazzthat Frets: 163
    I was looking at them too. Unfortunately not in stock .
    The Hosco set are exactly the ones that I have in the Ibanez packing, along with their fret files too.  I guess they've gone up through the years.
    same here
    I've ordered some Stewmac ones
    the reviews were better
  • prowlaprowla Frets: 4928
    Find out whether you need tapered ones or flat-edged.
  • FuengiFuengi Frets: 2850
    I have done a few with my Hosco set now. I'm happy with the results and the nuts seem to compare ok to my pro set-up guitars - my Strat set up by Simon Jones is my template for all things.
    The capo third fret method works great for me. I like to fold a business card in half lengthwise and slide that in the headstock side of the nut, it both protects the headstock and gives me an angle to work to.
    I check often and go lightly. When I get close I slow right down and use a really light touch. Don't forget, you can always take more off, harder to put it back!
    Take your time and enjoy it.
