Binding Already Finished Guitar Body
Is this even possible, let alone advisable?  I wouldn't want to do it myself, so do you think this is something a refinisher/luthier would be happy to do?  It would be on a poly finish tele.
  • FunkfingersFunkfingers Frets: 14799
    Possible? Yes. Economically viable? Only if you have deep pockets.
    A regular Telecaster body has a small radius cut around its edges. Unless your chosen binding is exceedingly thick, it will not blend neatly into the existing edges of the body.
  • I did it on a rounded edge set neck body with ok results. I needed to get the chisel out in places, but if its a Tele body you might be ok. Cut the binding channels, install said binding and get the sander out to smooth it all in*.
    *disclaimer: I may be a cowboy
    www.theflyingacesband.com
  • It's the sort of thing that a DIYer might do on their own guitar, but I suspect most professional builders would be reluctant unless there was an understanding that some level of chargeable refinish might be necessary.
  • That all makes sense - thanks for the replies.
