Parts caster project.
phil_bphil_b Frets: 2010
edited February 2021 in Making & Modding
I'm starting this thread in antisioation of a parts caster build but as it stands I have no parts
But I have bought a MIM strat body from a fellow forum member and I am just awaiting it to arrive.
I do already own a Roland ready Mex strat with 3 single coils so I'm thinking this one will be HH strat. I am very tempted by the vanson 57 classics
I'm still on the look out for a neck
  • nonesuchnonesuch Frets: 307
    joke removed after edit  =)
  • phil_bphil_b Frets: 2010
    So the body arrived and it is all in good shape. I will need to cut out to fit a neck humbucker.
    But I need some advice on necks. Will any Chinese no brand neck work or do I need to avoid 22 fret necks
  • SnapSnap Frets: 6263
    I have found with cheap necks, the boards can be very dry and the fretwork is generally rubbish and needs quite a bit of attention. Also will need a new nut.
    Depends what you want to spend, but tempus guitars, on ebay or instagram, do good stuff and will make to order if not already in stock. I don't know the price of his necks, but I recently spent 90 quid on a two piece ash tele body, as a reference point for you. It's lovely too. Soon to be butterscotch nitro!
    It all comes down to what you are wanting to spend really. But, for me, a duff neck ruins the whole thing as it's the part of the guitar you are most in contact with really.
    @Snap could you post a link to tempus. I'm having difficulty finding them
  • prowlaprowla Frets: 4915
    I have a HSS Strat:
    • Fender MIM body
    • Warmoth neck with roller nut
    • Seymour Duncan JB humbucker
    • Tonerider City Limits single coils
    • Stock Fender bridge
    • Fender tuners
    • Schaller Straplocks
    I've also got another I'm working on; I wandered into a shop and came out with the body and then have been putting the other parts to it:
    • Fender MIM body
    • Fender MIM neck
    • Fender tuners
    • Schaller Floyd bridge
    • Seymour Duncan JB (Floyd spacing) humbucker
    • Seymour Duncan single coils
    • 10-position Freeway switch, which adds humbucker/single coil switching and also neck+bridge
    • The hardware is gold coloured - I need a locking nut & bar
    @prowla well if mine turns out that good I will be pleased
    Cheers!
    The one with the Warmoth neck is really good - well worth picking up if you happen across one.
     https://imgur.com/gallery/sbxbmpK
    This is what I have so far
    Justin mentions at 13:00 a high pass filter on the volume pot on his new guitar. Is that a treble bleed or something else?
  • DrBobDrBob Frets: 3003
    I’ve just found them on Facebook if that helps ?
    Yes it might do. Thanks
    I decided to strip the body. The finish was in good condition but I really did not like the colour. And I can say someone at fender went to a lot of effort to glue all those bit of wood together to make a body  :o
    hi Phil, they are on ebay, and Instagram, don't think they have a website. I got mine on ebay, v good service and contact throughout.
    This weekend I have been mostly painting the body. I bought some nitro paints from Manchester guitar tech and I'm quite pleased with the results so far. Although the patchwork nature of the body does show through on some areas.
    I bought a squire neck via the forum and have upgraded the trem with a brass block from Northwest guitars. I did need to modify the trem plate as the arm hole did not line up with the hole in the block.
     https://imgur.com/gallery/sLg46Ng
    Here you can see where I opened up the hole for the arm. It does not look terrible but this guitar will not be a masterpiece that's for sure
     https://imgur.com/gallery/7eioodU
    The body now has a new colour and has been butchard to take a neck humbucker
    I long do I need to let the paint harden before I can start screwing parts onto it
  • FuengiFuengi Frets: 2849
    I think it's a good idea to let the nitro harden for a few weeks, maybe a month.
    edited March 2021
     https://imgur.com/gallery/ORcKHnz
    Well I have a functioning guitar. I'm not saying it's finished because it needs some setup work and maybe some other mods like better dot markers
    Oh and a few more pickgurd screws
  • normula1normula1 Frets: 640
    Looks great
