Given the way the standby switch has been done with the disconnected wire just 'insulated' with tape, and the unnecessary wire from the cap to the switch (much easier to just link it to the rectifier directly - you could even reuse the other wire!) then anything is possible.
Not sure who did the 3-wire mains cable conversion either. Death cap left in place (albeit disconnected) and earth wire not properly attached... hmmm.
I thought so too, but having it on what is obviously a patch from a removed transistor on the Bandmaster cap cover does make me think it's probably not Fender.
Sorry WHAT.
I am surprised by the value, which somewhat dissuades me from putting this amp on a freight container for two months
I'll do my best to get some better pictures! Absolutely clueless on the circuitry though, I was dreadful at electronics at school...
Anecdotally, pretty much everyone who's ever played this amp has offered to buy it on the spot. The hype and values look to be silly, but it really does have something very special about it.
Here you go mate:
Any chance you could read the values on the caps?
Sorry, tone caps, values... I'm a total newbie on electronics. Which bits are you referring to?
So, the resistors used on the anodes became exclusively Metal Film for noise performance - he favoured this specific type:
https://ie.rs-online.com/web/p/through-hole-fixed-resistors/8500937/
For capacitors in the tone circuit he favoured Polyester Sprague 6PS - generically referred to as "Orange Drops" however, not all Orange Drops are from the 6PS range.
https://modulusamplification.com/Orange-Drop-Capacitors-6PS-418P-Polyester-600v-P5536653.aspx
The number that's important is either printed as (eg) .047 on the one at the bottom right, or 103K/223K/333K on the other three. The voltage rating doesn't really matter in this application.
The red cap has a colour dot code (which is why they're called 'domino' caps) which is more complex to read.
Changing these values from the stock ones will change the voicing of the amp. Changing the type, for the treble pass cap (the 'domino' one) might also change the tone subtly - the original type would have been a ceramic I think, the 'domino' is mica.
No, just genuinely curious .
What's hilarious is that without the Dumble connection, this is just an old Princeton with a couple of caps changed and a rather crude standby switch mod, and it would in fact be worth marginally less than if it was original, no matter how good it sounded.
But because the great wizard Dumble touched it, it's worth thousands. That's not to say it doesn't sound great, and it may even sound noticeably better than stock, which is why I'm interested in those two caps - since they're the only parts that could be responsible. Although from memory, this model is extremely good-sounding anyway.
What's been done on the front panel between the volume and tone knobs by the way? Has there been a sticker or something, or an extra pot hole drilled and somehow filled again?
If that is correct, and the OP's amp is just a preamp tweak (rather than a replacement), I'd assume it would be more like £10k than £50k, but I'm just guessing.
