SOLD: Peavey Bravo 112 £90
I have too many Peavey amplifiers, including two of these. I need to make space for incoming.
Peavey Bravo 112 2-channel amp. 25W, all valve - 3x12AX7 + 2xEL84, Eminence-made Blue Marvel speaker, long tank spring reverb, effects loop.
I think it sounds great, but as I'm selling it I clearly have a conflict of interest. I was previously using an FX Stomp through FRFR, but this is much more fun. These combos sound even better through an external cab and, unlike the valveking, you can chose whether to run just an external cab or use both the internal speaker and an external cab.
It's in very good condition. The clean volume pot has been replaced and the replacement knob doesn't match the others but that's the only thing worth noting.
£120. £90 Pickup from SW19.
I was idly wondering yesterday if you can measure power by measuring the voltage across the speaker and doing a simple I^2R. I guess the inductance of the speaker means that this would overestimate the power.
U.
But measuring at more than the maximum clean power does significantly increase the apparent power output. Without an oscilloscope and a signal generator it’s often quite hard to find the point of clipping - and if you are using both those you probably want a dummy load anyway, since a constant sinewave at the amp's full clean power through a speaker is somewhat painful to listen to .
Even 25W is pushing it with a pair of EL84s if you go by a proper definition of clean, ie no more than 1% THD.
