Overdrive Level Pot Change? What do I need?
Thanks in advance for any advice to help me get this right
The level control on my Lovepedal OD11 is a 10k linear pot (I have checked the last part) but all the action - off > unity > lotsa boost -  happens the first quarter turn (clockwise)
I would like to change the pot if possible to have better control over level. Can anyone point me to what might do the trick? I can’t figure out log and reverse log - if indeed that would help at all.
If you were looking at the pot from the top, shaft side it is the centre and right hand lugs that are at 9.9k when the pot is CCW
thank you
This is the truth from hillbilly guitars!
  • ICBMICBM Frets: 73242
    You need a 10K Log.
  • Thanks @ICBM always so helpful
