I use Logic Pro X and have been quite happily using its build-in "Amp Designer" plug-in for a while now for recording electric guitars. But recently I fired up my (real) Princeton Reverb Reissue again, and it dawned on me that the Logic Pro X amps are not quite at maximo-inspirational levels for me :-).
I then read about IRs and as a result downloaded some free ones from Redwirez. I quite liked some of these used as cabs for Amp Designed amps - they seemed better than Amp Designer's own cabs. But I was still a bit disappointed when I set my results against the real Princeton.
I know I'm probably unlikely to get anything as good as the real thing, but I'm intrigued enough by the Redwirez experience to think that maybe I can do better than Amp Designer. So, does anyone have any recommendations for alternative amp plug-ins (ideally not too expensive)??
Or even tips for getting better sounds from Amp Designer? I mainly use clean sounds with sometimes a little bit of hair; I like both classic Marshall and Fender cleans. I (try to) do jazz as well as rock/pop.
Thanks for any thoughts you can share...
Amplitube 5
Brainworx VH4
STL tonality
Helix Native
Also have a bunch of thers that I dont use so much..or ever in the case of bias fx
The problem I have now with Digital stuff isn't that it's not good, it's that everybody sounds the same. I think I only notice this because I watch a massive amount of instructional guitar vids but it's kinda put me off. Actually using real amps with no digital processing at gives a more pleasing sound to my ears.
neuraldsp plugins
Hardware bass preamps.
One thing I tried yesterday: I used an amp sim that came with a software package I bought a while back called “MIDI Guitar”. The main point of the package is to drive MIDI software instruments directly from a guitar, and it does that really well. But I was pleasantly surprised to find that the throw-in amp sim, which I’d ignored until now, actually sounds pretty good - better than any of the Logic ones to my ear.
I’ve got the following:
- Audio Assault Sigma. Amazing! £5 or so? Sounds tremendous
- Nembrini Sound Master. £30 or so. Solid Fender ish setup. IR’s are very weak, sounds good with an external IR running via your favourite loader
- Neural Cory Wong. £70 - was my fav until the Sigma came along as the value just eclipses it, but the best clean sounds in town!
- Positive Grid Bias FX2. Utter bobbins. Just dire.
- Guitar Rig 5. Some okay tones but takes a little too much fiddling to get there and not as responsive as it should be.
- Guitar Rig 6. No discernible difference to 5, waste of money upgrading for me.
You could also create your own IR of your own cab and mic.
Helix
amps + mic'd up cab
amps + loadbox (although I need a newerer and betterer loadbox)
TACOMA NARROWS BRIDGE DISASTER
OK, next question :-) : what's a good reactive load box to get for a Princeton?
https://www.dv247.com/en_GB/GBP/Palmer-PDI-09-The-Junction-DI-Box-Specialized-Guitar-DI-Box/art-GIT0002334-000?campaign=GShopping/GB&ProgramUUID=5G_AqJarZwoAAAFl0FZyjI8V&gclid=CjwKCAiAyc2BBhAaEiwA44-wW1SXrqgTeDIJR7qLQjjNcWOyVxLwv8mWhoO_1t80mVH8ZkHpULG-_BoC8acQAvD_BwE
for cheap as chips results, Harley Benton do a attenuator with xlr out that you can plug straight into your interface and run an IR... £70 delivered.. works well...
Alternatively have a word with @dainty his latest album was done entirely with logics amp designer! and there is cock all wrong with the tones on that album!!!! “Dainty - ODAAT” if you want to listen...
Adding to which I don't have a cab sim for a 1951 Richard Allan Radio Bafflette Deluxe, so I have to use a real one.
Recently I've started to use the Waves guitar stuff a lot more. I bought the Gold bundle and that comes loaded with a load of stuff for guitar. It's simple and crisp and sounds great. I like it. I use that for a lot of bass too now. It's much more like using traditional amps, mics, cabs and stomp boxes.
I also have Eventide's TH3 which is very good. Sounds good.
I'll be upgrading Komplete to 13 soon, so will have a look at GR Pro 6 too, which is bundled with it.
Lately I've also started using my guitar dry straight into the DAW, and processing the sound afterwards. That's proving to be a useful alternative too.
With all this stuff, I find that you easily lose sight of what you want really, which for me is a straight up clean or dirty tone. For me, a lot of the software is just too FX and processing heavy.
When I first started in a band in the early 80s, all I used was a guitar a 2x12, a head, and a couple of stomp boxes. I find more and more I am coming back to that simplicity really.
I like a few of the LePou free ones as well as the free ones from Ignite, including their IR loader.
No need to pay for anything else.
What guitar were you using with it?
