Or are you using robust in some other sense?
I have the Ibanez Chorus Mini, and barring the bewildering lack of painted indicator lines on the smaller pots, like it a lot.
@dilbert ...agree 're shiny knobs but can be resolved with sticky tape and marker or you can even get push on matt marked tops that go on top of the knobs, or you can replace the knobs.
I had a Marshall regenerator before that but it had some kind of floating current on its chassis. Same as an iphone has when its plugged in and charging, could run your finger over it and feel vibrations on its metal shell and I didnt like it.
Shame, as if they sorted the bypass treble loss (whether true or buffer), I’d have another like a shot, as the chorus effect on it is great and compares favourably to the MXR 18v stereo chorus and also the Boss CE-2W.
True bypass... browsing Reverb one evening I spotted an MXR Analog for sale with a true bypass mod. I dithered and missed it but later found the link below. It’s not an easy mod to do but I did mine (without moving the switch) and it fine, slight click when engaged but no loud pop or thump.
https://www.diystompboxes.com/smfforum/index.php?topic=123744.0
I don't know anything about the VS pedals, but I can see that there are different versions. Which Chorus do you recommend? V1, V2?
I really love them.
