ringing open strings and the stopping thereof
VimFuegoVimFuego Frets: 15769
so, going through one of my periodic learning how to play with a pick phases and I seem to have this recurring problem, in that when I'm changing between open chords, the open strings continue ringing. I find it really irritating and as it doesn't happen on the vids I'm learning from, I have deduced it is a failure of technique. Any tips for stopping this from happening?
[/delurk]
  • RolandRoland Frets: 8838
    Can you damp the ringing string, either immediately or when the note needs to end, using left hand fingers? Finger tip or underside depending on where the finger is in relation to the string. There is a Tommy Emmanuel video where he talks through how he plays a particular piece. At one point he says (to paraphrase) if finger X doesn't damp the string then I catch it with finger Y.
  • VimFuegoVimFuego Frets: 15769
    generally it's the high E that rings, I will slow it all down and see if I can dampen with the pad of my pinky finger.
    'ee be prackersing richcraft!!!
    (I think that one's © Frank)
    Generally sporking, I think I'm usually muting either with the side of my picking hand, or the pinky.
  • vizviz Frets: 10762
    edited July 2014
    I use a daughter's hair band thingy. Also check out what Jennifer Batten uses. For legato solos I sometimes do the Steve Vai thing of putting my right hand all the way over by the nut and clamping the strings while fiddling and twiddling up top with the left hand.
  • richardhomerrichardhomer Frets: 24864
    Lucky Jennifer....
    good to know, but if we could keep things vaguely guitar related I'd be ever so grateful.
    ahem, sorry, when you say hair band thingy, is that to dampen the strings behind the nut?
    edited July 2014
    Haha yew-guise! :)
    The hair band sits just behind the nut, then when you want to do a twiddle, you quickly flick it past the nut to approx the first fret and twiddle away, then when you've finished your twiddle and want to play an E major chord or whatever, you quickly push it back over the nut again.
  • guitarfishbayguitarfishbay Frets: 7965
    edited July 2014
    By definition, if you don't stop the strings ringing they will continue to ring. The only distinction is to make sure you're not accidentally brushing the strings and causing them to ring. If it is just a case of strings continuing to ring rather than you making them sound again then the way to solve it is to learn more about string dampening. When playing with your fingers you can mute easily with your playing fingers (and notes dampen between picking as your finger strikes), when playing with a pick that often isn't the best option. I tend to use a combination of fretting hand muting and using my picking hand palm, or little finger for higher strings. A teacher might be a good option for a small number of lessons, it is hard to teach decent muting technique via text especially without seeing what you're doing now.
  • EvilmagsEvilmags Frets: 5158
    Learning to palm mute really helps. It's just a very quick touch and increases your dynamic range a lot.
