I know there are a million of these threads but I've perused them all and can't quite make up my mind.
I'm in the mood for a new amp, 100% used at home these days. Clean / mild dirt suit me, not really into the high gain stuff.
I have a THR 10C that I've had for years and it's fine. I've just sold my Stomp which I was using into monitors, mainly because I really just want to plug and play, rather than tweak and although the Stomp was completely brilliant, I definitely spend more time fiddling than playing. I've a few pedals knocking around from over the years to add a bit of colour.
Budget is up to around £600 (but lower is fine too) and it's unlikely I'll be able to buy used since I live in NI and the cost of posting an amp over here that is any weight is probably prohibitive, especially currently. There aren't many of interest for sale locally and it's pot luck if something comes up.
I've looked at videos and reviews of the following which I quite like the look of....
Blackstar Silverline 50c
Blackstar HT5R MkII
Marshall Origin 20c
Vox ACsomething ( I had a AC10C1 some time ago but it rattled a bit so not really tempted to go back there...)
I've also looked longingly at
@dazzajl 's TM Deluxe Reverb, which has thankfully now sold, and I must admit, I think it would be the dream amp for me with the power soak down to 0.2w. Is it worth spending £800 for a new one to scratch that itch?
Although I play at home, I don't need to be whisper quiet but can't go balls-out loud.
I used to think I was really only a Fender amp fan, but over the years I think I've broadened my palette - I love Marshall and Vox cleans and early breakup just as much.
If anyone has any sage advice, and, sure, what else would you be doing these days... please fire it this way.
Valves / Solid State / Hybrid, I don't really care. Not sure I want a billion amps / cabs / fx - happy with something that has reverb and, maybe, tremolo.
I await with baited breath.
Just because you're paranoid, don't mean they're not after youIt also has a range of outputs for home recording including USB preamp out I think
Any of the Victory preamps would do, or maybe even a couple of the AMT solid state pedal preamps.
I've got a slightly different thing, but also kinda the same, in my ADA MP-2 -> GPA-100 -> Jet City 2x12". It sounds epic at pretty much all levels from home-volume to divorce-volume, and I've got every confidence that it's going to sound just as good at band volume.
What you have to remember is that even 1W is way too loud for any reasonable neighbours to put up with, but lower than that and you're really strangling the signal too much for most valve-based power sections to sound decent.
Digi - all sounds a bit convoluted for me! I kind of want one box rather than a few separate things. I get what you say about the 1 watt thing but as long as there’s a master volume of some sort, I’d be fine without annoying neighbours.
The demos I’ve seen of the TMDR sound superb even at the 0.2w setting - although since they aren’t valve, maybe that’s why.
Silverline looks quite interesting too as a non valve solution but might have a bit too many options.
EDIT: sorry I re-read your post and somehow hadn’t considered budget.
Spark is exactly the sort of desktop amp I want to avoid. Too much fiddling!
On the other hand, something like the Mk2 Blackstar HT5 also sounds very good, cleans sound much better than the earlier HT amps and it has a 12” speaker but a 0.5w mode too. Would leave some GAS funds for another toy.
@clarkefan Again, it’s not one box.
It also has one of the best sounding headphone out tones, thanks to a nice stereo verb on it.
not sure how much the studio classic/vintage combo’s SC20c / SV20c go for used, they sound incredible.
Lots of choice about, might be worth listening to a few YouTube demos /shootouts of a few different amps if you’ve not already.
