No holes but a bit of a mark on the center of the baffle where it might have been.
I have to say I'm not massively enjoying vintage Marshall cab ownership so far... I don't think it's a fake because everything else seems as it should be though.
Can anyone spot the sneaky issue with one of the speakers?
It does actually look like there was never a post fitted, but the baffle does look original.
For what it's worth the G12S is a really nice and very underrated speaker, but it probably won't sound good in a 4x12" with three Hs.
Presumably someone took all the speakers out to check them when they replaced the broken one.
Are there any other signs that these cabs might not be genuine? All the corners/handles/skid tray etc look correct.
To be fair it still sounds pretty good, even with the odd speaker and missing the brace.
I'll definitely replace the G12S. The cone on it has a tape repair and what looks like another un-repaired tear. I was thinking I would avoid the minefield of looking for a vintage correct replacement and just go with the re-issues.
I've only played at relatively low volumes so far which is maybe why I haven't noticed any issues with the G12S.
I want to pull the speakers out and try them each through a 1x12 at some point to get a better idea of how they sound individually.
@bygonetones Thank you for the link. Very useful!
Yes, I would given that a 55Hz G12H-30 reissue is available. Buying old ones is pot luck, because as bygonetones says so many of them have issues which the seller may not know/care/admit to.
I want to replace the particle board back panel anyway so I think I'm going to strip the whole cab down and refurb it.
Need to get the speakers back out and give them a clean/inspection.
If anyone's interested, here is the 'repair' on the G12S next to what looks like another tear:
