I'd be looking at a better amp, but that's only coz I'm not keen on the Micro.
Gives you a single cut, P90's for a bit of a different sound vs SG and Strat.
You’ve got a stratty guitar with a bridge humbucker (as Sassafras says, very versatile), a fast shred rock guitar in the Axis and a classic blues rock guitar in the SG. Quite a few bases covered there.
https://www.epiphone.com/Guitar/EPIBDM867/Casino/Vintage-Sunburst
Are you looking to compliment that one or make a change?
Of your three candidates, the Squier is the most versatile; vibrato bridge and a broad texture of tones from full-throated rawk on the bridge humbucker to more subtle single coil tones.
Another option - and right at the upper end of your budget - is a PRS SE Standard 24. Very well put together, vibrato bridge, 24 feet neck and twin humbuckers with coil splits for when you need a bit of single coil quack.
Otherwise, of those you mentioned, the Strat would be very versatile indeed.
