What's it like without the Ox box?
Personally I would fit standard Shuguang 12AX7s - you only need three, V4, V5 & V6, unless you use the Vib/Trem channel alone (the Vib/Trem also uses an ECC82 in V3, but you don't need to change that) and JJ EL84s.
@dodge exactly that’s why I think a new set of tubes is needed as I only use the brilliant inputs. I can’t turn it up much at all in the house because of how loud it is though it doesn’t sound as clean as it did last time I played it out ( just over a year ago)Was distorting much earlier than normal and not necessarily in a way I like.
It's worth changing them one at a time to see whether any are more worn-sounding than the others. Also, if you don't use Shuguangs for all three then you still should use one for V5 as it's a cathode-follower and other modern types tend to fail there.
V1 is the vib/trem channel gain stages
V2 is the vib/trem oscillator
V3 (ECC82) is the vib/trem mixer
V4 is the gain stage for the normal and first gain stage for the brilliant channels
V5 is the second gain stage and tone stack cathode follower for the brilliant channel
V6 is the phase inverter
Some schematics have the numbering reversed so V1 is the rectifier, V2-V5 are the power valves and V11 is the oscillator, or even a more random order!
In any case, if you don’t use the vib/trem channel you only need to worry about the three closest to the power switches.
[This space for rent]
Hmmm, interesting, Ive heard an ac30 6tb with the 5751 in the preamp v1 and it sounded great. Maybe ill just stick with the 12ax7 though. Didn't want to go down the rabbit hole of valves which has opened up lol!
