I decided I wanted a new guitar that didn't scream 'Metal' too much and I was all set on a Charvel Pro Mod So Cal Style 1 in Snow White. The problem is that I went to try one today and although it sounds great, after two neck-thru guitars and four PRS SE Custom 24 guitars, the upper fret access felt awful due to the thick neck joint. Back to the drawing board!!!
I want a guitar that's naturally brighter than my set-neck PRS guitars so I was thinking a bolt-on. I'd also prefer the body wood to be Alder with a maple neck, like the So Cal but mahogany might be OK. I don't know much about other woods but the bottom line is that it should be a relatively bright guitar, like the So Cal. I'm not too bothered if it's 22 or 24 frets but it needs to have a Floyd Rose 1000, not a Special. I'm also looking for an HH configuration or maybe HSH at a push.
The two alternatives that immediately leap to mind would be the Charvel Pro Mod DK24 HH FR or the Jackson Pro Dinky, as they're essentially the same guitar. I like the Charvel DK24 but the quilted amber top and gold hardware isn't exactly subtle. I also like the Jackson Pro Dinky but while I like the So Cal in white due to the black pickguard, I'm less keen on the Jackson in all white and in an ideal world, I'd like to avoid a pointy headstock.
What other options would be good for me to try?
If it's an Ibanez, it would need a locking bridge that is at least as good and reliable as a Floyd Rose and as I don't know which Ibanez trems are really good and which are poor, I've avoided the entire brand so far. Some information on the Edge bridges would be very useful.
There seems to be various neck-thru options around and I love the upper fret access on them but when I had my SL3 Soloist from Japan, I found it a very hard guitar to get pickups for due to the dominance of maple running throughout the guitar. This was of course the days when the maple from the neck went right through the body and the body was essentially just wings glued onto the neck, perhaps they're different now.
Any suggestions?
That's a shame to hear about the Charvel though as I was looking at those too as something a bit superstratty but not too metal looking. I'm not keen on bulky Fender style neck heels and hoped the Charvel would be better.
I'm coming to the conclusion that unless I get the Charvel DK24, it's probably going to have a pointy headstock and I'll just have to live with that.
I'll check out the M, Horizon and Musicman now.
I fully realise I need to play the guitars, this is just about getting a shortlist and knowing what to look for instead of wandering aimlessly. The Schecter Hellraiser C-1 looks interesting, though I'd need to change the electrics to install passive pickups as I really don't like actives. I also looked at an Ibanez Genesis RG550 but I don't know if the Edge bridge is any good or not.
A guitar that did catch my attention is the Ibanez Nita Strauss Jiva, even though I know very little of her as a guitarist. It has the bolt-on neck, a slim mahogany body, I can live with the HSH configuration and I THINK I'm right in saying that the Edge-Zero II bridge is one of their good trem systems.
Is it as good and reliable as a Floyd 1000?
The other thing I was curious about is what is the difference between the Jiva10 and the JivaJR that justifies almost twice the price? I can see that the body on the JR version is Meranti instead of mahogany but I've never heard of that before. What is it like in comparison to alder and mahogany? Is it any good or just cheap rubbish? The only reference I've been able to find online suggests this wood is so poor, that's where the real difference is. Other than a slightly different neck carve, the only other difference I can see is the pickups, which don't bother me as I'd be installing a Super Distortion, Area 61 and PAF Pro in it anyway. It doesn't seem much difference for a huge gap in price.
Beauty is in the eye of the beer holder
My trading feedback - I'm a good egg
On the boring subject of guitars, I don't want a single coil in the neck so the Satriani is out.
I know the Pro Dinky and DK24 are serious possibilities. The Hellraiser looks good other than having to switch from actives to passives. I like everything about the Jiva10 except for the price, which seems very high given that the first thing I'll do is remove two of the pickups!
Ibanez’ hardware generally seems to be above average from what I can tell?
The Jackson Pro Dinky, Charvel DK24 and Schecter Hellraiser C-1 are all definitely in the mix. The Ibanez options I'm finding more confusing because I have no idea about the quality of the bridges.
Ibanez Nita Strauss JIVA10 - Fantastic except for the price (Edge-Zero II bridge)
Ibanez Genesis RG550 - Looks solid enough, though I've never used basswood before (Edge bridge)
Ibanez RG370 - Looks astonishingly cheap given that it seems to be using essentially the same bridge as the JIVA10 at well under half the price! Never used Ash before either but I can't see an obvious reason why it's so much cheaper than everything else (Edge-Zero II w/ZPS3Fe bridge)
Can anyone tell me how each of these bridges stack up against a Floyd Rose 1000?
Floyd 1000 are good. Floyd specials can be okay
So, you want a neck through for access but not the maple core? In that case, look at esp ltd H1000/1 - these have a deep set neck into a mahogany body with a huge carve for the same feel as a neck through.
Alternatively, here is a nice ibby I found that is screw on neck but with a nice bit of shaping.
https://www.peachguitars.com/guitars/electric-guitars/ibanez-rg1120pbz-ckb-charcoal-black-burst.htm
