Nut/string guide material with a zero fret
SeziertischSeziertisch Frets: 1375
I have a zero fret Gretsch and the strings to bind on the nut/string guide behind the zero fret.
Lubrication makes a difference, but has anyone replaced the string guide on a zero fret guitar with a Tusqxl or Teflon one?
  • KittyfriskKittyfrisk Frets: 19365
    Have you tried dressing the existing nut slots to reduce the binding?
  • ICBMICBM Frets: 73033
    Yes, but not with plastic - try brass. With a little lubricant it's far lower friction than any plastic, which is why it's often used for bearings in engineering. If you could make it in phosphor bronze, even better...
  • SeziertischSeziertisch Frets: 1375
    They’ve been dressed, it’s just that they need to be kept lubricated, though maybe a bit more dressing would be in order
    Any particular makers you’d recommend?
    Sorry, no idea, I would make one from brass stock.
  • SassafrasSassafras Frets: 30320
    I bought one off ebay ages ago.
    Can't remember which supplier though.
  • stonevibestonevibe Frets: 7211
    You can make a jewellers mop out of a piece of string, just unwrap it to make it all strands. Then use a little Brasso and the mop to 'polish' the nut and it will make it smoother on the nut slots.
    Guitar Bomb & Nembrini Audio Summer Giveaway
    Thomann do Webster adjustable brass nuts for a variety of guitars including a 'single cut'  https://www.thomann.de/gb/abm_6210_webster_nut_lp_style.htm
    I have one that came on an acoustic I bought. Possibly not the prettiest nut ever, but works well and is surprisingly adjustable.
    I’ve a friend who has fabricated some bridges and bits for me in the past, I think I’ll reach out to him
