I currently have a Canon 50D DSLR which by modern standards is getting a bit long in the tooth, but I like its size and weight.
I have 3 EF-S lenses and a 24-108 EF L lens.
Having had a brief look at the camera landscape things have obviously changed quite a bit in the last 9 years.
Would you recommend, sticking to what I’ve got as it still takes good pictures (I’m probably the weakest link)
Upgrade to the modern equivalent (90D) or upgrade to the next range up possibly second hand (5/6D) and throw away my lens investment (except the L lens) or do I embrace the new mirror less cameras (can I still use my lenses?)
Video does not interest me much, and I do most of my shooting in RAW in either Manual or aperture priority mode, mainly landscapes or my dogs.
I ended up getting a Lumix GX80 instead, at £420 - it's for streaming and recording videos, so a mirrorless that can do 4k for hours on end without overheating was kind of necessary. Just starting to get the hang of it, will probably end up getting at least one more lens - f/1.4 or f/1.7, I think, for the fashionable shallow look.
Admittedly, these seem to be considered "budget" cameras, which boggles my mind a bit. I mean...I just spent more on the GX80 than I did on my entire amp/effects rack (which I'll probably do a lot more with).
There are really two main questions you need to answer. First, what sort of photography do you do? (This will bear on the question of whether to retain the 50D or upgrade.) Second, what are your three EF-S lenses? If one is (for example) an 18-55, then it is worth next to nothing anyway. On the other hand, something like a 10-22 or a 17-55/2.8 would be very hard to replace. (Well, easy enough to replace, hard to pay for, I mean.)
The touted advantages of the mirrorless generation are mostly bunkum. I bought an EOS R myself but after 12 months of frustration and annoyance with it, sold it again. Most frustrating camera I have ever owned. (I still have four Canon SLRs, three of them easily superior to the EOS R ergonomic-wise, and the other (a 5D II) so old that we won't hold too many things against it.
We still have a bulb setting, why? Surely you should be able to just type in a long shutter speed rather than relying on an external trigger.
Also with digital why can't you have digital shutter speeds that vary across the sensor for HDR photography so parts of the sensor that are seeing dark are switched on longer than the parts that get a lot of light, rather than bracketing and stitching together afterwards.
I'd only be selling to go the other way - fixed lens compact! I think I tend to use a 28mm or 35mm lens about 90 percent of the time... Let me know if you're interested. Boxed with everything, and have a great 50mm stm and a Tamron SP 70-300mm lens to go with it.
The trouble with the mirror less designs is they are just too small for my hands. I used to have a 350D only once I added the battery pack did it feel comfortable.
You might get consumer level cameras starting out with lots of features behind menus and sub menus, but the higher you go, the more tacticle and physical the buttons get.
But if you want to save money, you should share the same system and lenses.
Obviously that's no help if you don't like the cameras - I can totally understand if you don't like how the controls work compared with a standard PASM dial. I'm the other way around, where I love the Fuji controls and now find anything else frustrating.
In fairness also, most camera lenses these days are excellent. A Canon nifty 50 is a fantastic lens, the same way the fuji 35mm 1.4 is. It's also cheaper - fuji now have the plastic 35mm F2 which is a great thing to have in the lineup!
I'm still sad that m43 is struggling a bit, I think it's the ideal size/cost/price/quality combo for most people that don't shoot for money (and maybe quite a few of those that do!).
I also prefer the Fuji controls more - but can work with both.
