https://darksitefinder.com/maps/world.html#4/53.09/0.35
Ideally you want to go to somewhere that is Dark Green or Blue. Black if you are that lucky.
What you are lacking is a fast wide lens. The 50mm is fast, but too narrow for untracked photography.
If you can find yourself an inexpensive used lens with an aperture of f/2.8 or wider, and 18mm or lower focal length, then you'll be able to get plenty done. On my Fuji camera I used a 14mm f/2.8, which was pricey, but you can get similar lenses for Canon mount that are much cheaper, especially used.
Having watched a really good tutorial
Looks like I need some stacking software.
I can use the EOS software as a intervalometer.
