I wouldn’t be in a hurry to run it with another cab though, they’re rather sensitive to low impedance and can distort in a really horrible way or even fail. They sound great and seem reliable into one cab, so I’d rely on putting it through the PA if it’s not loud enough, or get a more efficient single 8-ohm cab and just take the head section.
It'll take a 4 ohm can or two 8ohm cabs to run at the full 350w.
To be honest at this stage I'm still not convinced I need it as this thing is pretty chunky. I only really need volume for stage monitoring, as it runs out to the PA anyway.
Just because you're paranoid, don't mean they're not after you"Take these three items, some WD-40, a vise grip, and a roll of duct tape. Any man worth his salt can fix almost any problem with this stuff alone." - Walt Kowalski
Great sounding amp though, you'll enjoy playing through it!
I also had a Micro VR, which is essentially a PF200 in a mini-SVT-style box (with a transformer rather than switch-mode power supply), and that did the same things. It sounded perfect through its own little 8-ohm 2x10” but wasn’t quite loud enough, and misbehaved through a 4-ohm cab.
If you can avoid running them at 4 ohms they’re really nice though.
Feedback : https://www.thefretboard.co.uk/discussion/58125/
