Pedal cables with pancake ends?
hubobuloushubobulous Frets: 2372
So I'm moving from using a Rocktron Utopia with a couple of extra pedals to a complete pedalboard with valve amp. I'm not yet sure on the layout of my pedals, but there's a chance that it could be a squeeze, (depends on which pedalboard I buy), therefore it struck me that the jacks on cables can be a culprit of space occupation...!!
I'm not anal about this, and whilst a tidy pedalboard would be nice, it doesn't have to be a work of art. But the pancake ends could make sense, but I have no idea if there are good/bad ones, or if they're just not worth considering.
Anyone with experience in this sort of area, please chime in :-)
  • guitarfishbayguitarfishbay Frets: 7974
    edited July 2014
    Doesn't Kabl stock or make these? @RobDavies
  • EricTheWearyEricTheWeary Frets: 16669
    Forum wisdom says buy Kabl for pancakes, although I seem to remember some suggestion ( @ICBM ?) that pancakes are inherently less reliable?
    Having just redone my tiny, tiny board after putting everything on realised I couldn't do it the way I wanted due to the jacks on the patch cables,so I ought to be considering pancakes as well. However, my first thought was to move from a flat board to a pedaltrain type one so excess cable and power cables would be out of the way which would be a space saver, less squishing on the cables ( technical term) and generally tidier.  I wouldn't go down the route of making custom patch cables as that doesn't seem the best idea if you move everything around every month.
  • JDEJDE Frets: 1092
    How many do you need? I have some of the small Kabl patch cables with pancakes floating about. PM me your address and you can have them if you want.
  • hubobuloushubobulous Frets: 2372
    Hey @JDE. I have no idea how many at the moment, but a free offer is most kind and accepted. PM on its way.
  • LewLew Frets: 1657
    The Hicons that Rob uses are good.
  • hotpickupshotpickups Frets: 1826
    I use pancakes and they have given me no trouble. Maybe to do with the amount of solder I used though. It was my first time at soldering :)
  • joeyowenjoeyowen Frets: 4026
    I can't remember what people say, does solder help or hinder tone.
    Does it lessen or increase resistance?
    Or does it depend who you ask?
  • BradBrad Frets: 700
    edited August 2014
    I've used pancake ends with varying degrees of success. However I now use the Evidence Audio SIS ends. Granted, they are solderless but I've never had one go bad on me after about 2 years, sound integrity to my ears is as good as any soldered patch cables I've used and they are really easy to make. Plus they have a tiny footprint, great for saving space and keeping things neat and tidy.
    Pretty expensive though...
  • John_BlackWolfJohn_BlackWolf Frets: 137
    edited August 2014
    I purchased a bulk of the Hicon ones from Thomann. Used with the very thick klotz ac110 I've found them totally reliable.
  • capo4thcapo4th Frets: 4437
    Hicon from Kabl have given me no issues
  • shuikitshuikit Frets: 224
    I also got a load of Hicon ones from Thomann and some Sommer cable, not had a problem with them either.
  • ecc83ecc83 Frets: 1747
    The only problem that I have had with pancakes is the tiny screws working loose (but then that happened with the early Cannon XLRs!) .
    Locktite or nail varnish or better, some heatshrink which also give a degree of cable relief.
    Resistance in signal cables, even several k Ohms, will make diddly diff' It COULD conceivably be a problem in a speaker circuit but hardly ever is. Anyone's jacks getting hot?
    But yeah, give Rob a drink!
    Dave.
