Solution:
Sub oneEighty()
Dim sld As Slide
Dim shp As Shape
Dim sr As Series
Dim chrt As Chart
For Each sld In ActivePresentation.Slides
For Each shp In sld.Shapes
shp.ThreeD.RotationX = 180
Next shp
Next sld
End Sub
Anyone know if I can do this easily? I have no experience of VBA but used to write code.
What i want is 2 macros that does this (pseudo code coming up)
For each slide
Select the textbox on the slide
do format shape - shape rotation - rotate 180 degrees
I'd then like a second macro to return it to 0 degree rotation.
I can do it by hand but have 5 presentations each with about 70 slides so it's very time consuming.
