Can I rewire a strat so that the 2nd tone pot works on the bridge, in addition to master tone pot
I would like to roll off the treble on the bridge, and have the middle tone pot as a master
Has anyone seen any good circuits?
  • ICBMICBM Frets: 72409
    Disconnect the wire that goes to the neck pickup tone pot at the switch end, and connect that to the top terminal of the volume control, or to the link between the two halves of the switch, whichever is easier. That's now a master tone control.
    Then disconnect the wire that goes to the middle pickup tone pot at the switch end, and connect that to the unused terminal on the tone control side of the switch - ie move it along one. (Or just the one closest to the link to the volume pot, if it was already wired to both middle and bridge pickups.)
  • FunkfingersFunkfingers Frets: 14452
    edited April 2021
    Wot he said.
    Other than having different capacitor values, I'm not sure why anyone would want this mod.
  • ToneControlToneControl Frets: 11916
    Wot he said.
    just to tame the bridge when needed, without having to tweak the pot mid-solo
    Ideally, I'd have a separate pot for each pickup, like an LP
    Actually, tone for Neck+Mid and another for bridge could also work
    That’s really easy to do. Just connect the upper tone pot to both neck and middle terminals, and the lower one to the bridge terminal.
