*FS* PEDALS! Price drops! Wampler, Thorpy, TC Electronic, Aguilar and Mooer...
Circu5Circu5 Frets: 4
edited July 2021 in FX £
Hi! Lots of pedals here to scroll through, from top to bottom. As you'll see in the pics, some are a bit scuffed and others are in good nick. Some have their original boxes, others don't. Some have Mooer pedal toppers for easier stomping (easily removed). Some are primarily designed for guitar, but most also work brilliantly on bass. Most have velcro on the back. But all work perfectly!
  • No trades.
  • Bank transfer preferred (I'll provide bank details in private message).
  • All prices include postage within the UK. For price outside UK, please message me.
Cheers!
Steve
Wampler Pinnacle Distortion Overdrive Pedal - £75 including postage Fantastic pedal - does everything from low gain to full distortion. Quiet and versatile distortion pedal. Great British stack tone. Tone, Volume, Gain and Mid Contour knobs. Modern / Vintage and Boost / Gain switches. Made in the USA. Get that distinctive Brown Sound from the Pinnacle. This is the version 2 pedal which builds on the original while still letting you get those classic Van Halen tones. It is especially good at doing high gain without sounding too muddy or saturated. The Vintage and Modern modes will sound softer when flicked down and more treble-y when up.
Steve Tilling - frontman and guitarist for CIRCU5 and EXTC (feat. XTC's Terry Chambers)
  • Circu5Circu5 Frets: 4
    edited May 2021
    TC Electronic Hall of Fame Mini Reverb - £50 including postage Hall Of Fame Mini comes in a small package but houses some of the biggest reverbs around. Provided by the reverb industry leader TC Electronic, this pedal is capable of all the renowned TC Electronic reverbs including spring, hall, room, plate, cathedral and many more. Hall Of Fame Mini also sports full TonePrint functionality, allowing you to use tones customized by your favorite artists, including guitar legends such as Steve Vai, Paul Gilbert and Steve Morse. True bypass and an Analog-Dry-Through guarantee no tone coloration, zero latency and no conversion of the dry signal for absolute tonal transparency. Specifications TonePrint enabled - load HOF Mini with your favorite artist’s tone Room for choice - swap between a smorgasbord of renowned TC Electronic reverbs including spring, hall, room, plate, cathedral and many many more using TonePrint Ultra-small footprint - will fit on any pedal board True Bypass for zero tone coloration Analog-Dry-Through design - no conversion of the dry signal for absolute tonal transparency and zero latency Works flawlessly with guitar and line level/FX Loop signals.
    edited May 2021
    The Dane (Thorpy FX) - Overdrive - £185 including postage "THE DANE is a creation designed to meet the exacting needs of Danish Pete. However due to the design brief needing to cover the wide palette of sounds he uses, the pedal finished up being the most versatile pedal available on the market for such a clean design. THE DANE has two sides - a complex light to medium gain overdrive on the left and a high headroom super clean boost on the right. The pedal is designed so that the boost runs into the drive side. This yields three distinct tonal variations ranging from clean boost all the way through to full and fat saturation. The pedal is also designed to clean up impeccably from your volume control and as such it is ideal for dynamic players who like to adjust their playing style. Size: (W)100mm x(L)125mm x(H)53mm."
    Aguilar Agro Bass Overdrive Pedal - £80 including postage
    Goes from warm overdrive to full out fuzz and distortion... superb pedal that easily avoids the dreaded bass dropout of other overdrive pedals...
     "The Aguilar AGRO is every bass overdrive you will need in one pedal. With just four controls you can go from all out bass distortion assault to a sweet warm, tube like overdrive like you would hear from the Aguilar AG500 that this pedal is based on."
    Mooer Micro Preamp 013 Matchbox - £30 posted "MOOER micro preamps are sonically accurate digital recreations of the preamp sections of popular tube amplifiers. We have developed these by directly analyzing real tube amplifiers using a brand new technology to capture their sound, dynamics and response. Each Micro Preamp comes complete with dual channels, integrated speaker cabinet simulation and dual operating modes to suit the needs of all users. Features: • High quality dual channel preamp • Independent 3 band EQ, Gain and Volume controls for each channel • Speaker cabinet simulation on/off • 2 different modes for footswitch operation. On/Off or channel A/B Connection: 1.DCIN: Connect a DC 9V 300mA centre pin negative power supply 2.INPUT: Connect your instrument directly or the output of your pre, pre-amp effects like Overdrive, distortion, etc. 3.OUTPUT: Connect to a power amp or your amplifier’s effects return.(Highly recommend using a tube amplifier) Different power amplifiers will affect the outcome of the final tone.You can also connect directly to a sound card and activate the speaker cab simulation for recording purposes Note: You can connect your "fx loop" effects, like modulation and time based effects, in between the MOOER preamps output and the input of the power amp (fx return)"
    edited May 2021
    Sold
  • Can I take the drop off your hands?
    Hi, I’ve just messaged you. Cheers!
    edited May 2021
    Sold.
  • ZoolooterZoolooter Frets: 886
    I’ll take the flashback mini if still available. Cheers
    edited May 2021
    Sold
    edited May 2021
    Sold
  • gamagama Frets: 24
    Hi
    i will take the flashback delay normal
    cheers
    edited May 2021
    Sold
  • welshboyowelshboyo Frets: 1812
    Hi, I’ll take the Radar please if still available?
  • andymanandyman Frets: 58
    Aw snap. I'll second for the Radar if welshboyo ends up passing.
    edited May 2021
    Sold
    Bump
    Bump with price drops - some bargains here!
    Tickled prices in a downward direction...
  • JamieLFJamieLF Frets: 50
    Bumping this for a top notch seller - recently picked up a G2 from Steve and couldn't be happier with how the deal went :)
    Thanks Jamie! Top man.
    Bump
