If that fails, try WD-40 - the normal stuff, not the contact cleaner. It's not the 'right' product, but it can be effective if proper contact cleaner has already been tried and failed - it's a shot to nothing at that point since the only remaining alternative is to replace the pots anyway.
For some reason WD-40 seems especially effective (and usually necessary) on 1980s Marshall pots, I have no idea why!
And don't ever use WD-40 on digital encoder 'pots', it will wreck them.
One is something like computer cleaner and quickly evaporates leaving no residue. I'll try this first. Good for cleaning and safe to use on most things.
The other is a lubricant type that does leave a very fine oily residue. This cleans and protects metal parts.
In other words I think it's worth having more than one type to try. They should last for ages as you want to use them sparingly. If you do want to soak the thing take it off and put it in a small container and leave it over night.
