This is inspired by a recent
@HarrySeven acquisition (thread here) of a guitar based on plans in the October 1974 edition of Everyday Electronics magazine.
I built one myself at the time using whatever tools were available in my school's woodwork room and whatever materials I could find.
It wasn't bad for a first attempt but I was no Brian May:
@WezV suggested that we should have a forum build off from those instructions so I've taken some measurements, made some drawings and a (rough) mockup:
...and had some templates made.
The main constructional difference is that Mark II will have a truss rod. Everything else will be due to better hardware availability, power tools and skills.
And now I have some timber (there's also a rosewood fretboard not shown:
The truss rod nut is between 5-10mm deep under the fretboard. This means that if I have a headstock end adjustment it lies within the headstock thickness.
I think what I'll have to do is rout a cavity for the Allen key.
I don't know however how to drill the hole for access to the truss rod.nut. I suppose I could rout the channel all the way and add a fillet above but I'd rather not. I can't see any other way though?
Forum feedback thread. | G&B interview #1 & #2 | https://www.instagram.com/_harry_seven_/
If anyone would like the templates I'd be very happy to pass them on.
Instagram
I've just noticed how untidy the base of the bridge pickup rout is.I'll tidy it before I paint.
Cut the neck blank:
and routed the truss rod channel.
I couldn't use the template for this as (i) I decided to make the adjustment at the heel end so the template wasn't right and (ii) I destroyed my small 3/16" bit that I was going to use. I think I over-revved it.
The sled is made from an old picture frame screwed to a sheet of 19mm ply.
Here's the truss rod in place:
Next job is to radius the fretboard and glue it on...
First I milled the transition to headstock from the nut using a ½" bullnose bit. The shank of the bit has a ball bearing which ran along the perspex:
then I used a StewMac Safe-T planer to thin. Despite its name, this is a scary tool. Luckily the little bit of tearout in the picture was inside the waste.
Finally I block-sanded smooth as the planer leaves quite a lot of circular marks.
The folks at Everyday ELECTRONICS would be amazed.
Instagram
And frets in:
Just the back to carve now.
I left that til last as it's easier to fret the square wood using my pillar dril to press the frets in.
I made a cut at each end using a tenon saw
Carved the shaft to approximate profile using a rasp
Then blended the transition at headstock and heel using the half-round side of the rasp
I'll use some 80 grit paper next to smooth it out closer to the final shape... there we go
Before that though I have to decide which type of bridge to go with. That'll determine how deep I set the neck in its pocket.
Using a scraper to ensure the surface is dead flat and take out any sanding scratches
Packing the grain filler using a card:
and after wiping off using coarse hessian. I hope you can see in the reflection how shiny and flat it leaves the surface. It should just need a light sand before sealer coat tomorrow.
Nut is fitted, I'll tidy up as part of the setup
First coat of sanding sealer on the body. I think this deserves a clear finish:
Then worked across the flat surface, holding the can close to ensure the lacquer went on wet, working in overlapping logitudinal bands:
Until I had an even coat right across:
⅔ of a can of Clear Red later, it looks like this:
Should look smart with a white 'guard I think.
I've tried a few logo ideas, not very inventive sorry and I know that there are guitars sold under the Delta name but this is obvioulsly not one of theirs!
