The laney is more gain, and to my ears less bright and present. You can mod to jcm800 spec though. It is a loud single channel rock amp though.
I really rated them back in the day, they were affordable and decent. The lh50 was my first big amp - toroidal transformer to keep it smaller, two channels and a modern switch that changed the voice (but not gain - it was not a high gain amp!). It was the head version of a combo...
My experience is with the older 50w version though
Another thing that I seem to remember though is that it had switchable valve options in the 50, and I think my mate's one had 6L6s in it? If so, that'd explain why it didn't sound as much like a Marshall, when it might have done with EL34s?
EDIT: checked, yeah it has a 'bias switch' that allows you to use EL34 or 6L6 power valves
Vinnie Moore advertised the AOR, which bizarrely is responsible or a lot the interest in Matamp these days.
For me they really need a boost just to get the right feel, without it the feel was really flat and hard to play whereas I find a Marshall feels quite easy. I wish I'd just tried a treble booster with mine to give it more of that upper mid sizzle and bite I wanted. Was good with a Rat.
The Marshall is less compressed and has more presence to my ear. The laney I remember sounding a bit more modern, less dynamic.
I'd pick the laney for modern rock, but the jcm would take my pick for just about everything else.
The main driver for the explosion on Matamp was Sleep. They had rented Orange amps for the holy mountain tour. and needed them fixed. They got taken to the matamp factory and ended up getting a load of green amps, including 4 of those ridiculous 4x15 cabs with the handles in the wrong place. Nearly all the talk I've ever seen about matamp has been based on Sleep using them. OF course, Pike used an AOR for Holy Mountain and went back to it fr the first high on fire album.
I had a gh50l before i went with matamp and it wasn’t up to much . But I think in retrospect I’d liked to have tried it with new valves and a decent cab , I don’t think those h h speakers were up to much.
My experience with Matamp has not been great, all 6 cabs I owned or used on tour have had seripus quality issues.
When I supported High On Fire he was using Soldano and Marshall.
This is a gh50l into a klipp cab with greenbacks
Agree that they're very sensitive to speakers. The first cab I had with mine came with Eminence Legends and it was horrible, very bright and brittle. Much better with the G12H30s which I used for years but wish I'd tried the H30/V30 combo sooner as that was even better and took out some of the fizz. I suspect 2x V30s would have suited it better still to get more of that upper mid stuff I wanted with less of the harsh/fizzy H30 top end. Sounded huge through a Mode Four cab too.
That being said, I've never tried an 800 (I've got a GH50L) and pretty much everyone on here (and elsewhere) says the Laney doesn't sound the same as an 800, so I believe them. Different parts? Circuit layout? FX loop? Something else? I dunno. But there must be some reason...
