I used a Blackstar HT5 myself, through a large 1 X 12" .... we did about 250 gigs together with those amps
Rift Amplification
Brackley, Northamptonshire
www.riftamps.co.uk
Is that a Sho Bud Lloyd Green model?
5E3 works for me without micing at most gigs I play on guitar or steel.
The steelie is Kevan Bartholomew. I know he has or had a Sheffield, but he also has a Mullen,, and whatever is in the pic below. He certainly doesn't use a 5E3 though - that's his amp botom right.
EDIT: Yes he has/had a Sho-Bud.
I also found that a treble boost was of little use for a boost for solos on that amp. I found that the amp simply compressed more because the headroom was not there to be able to push more cut through the mix.
That being said.... what a bloody great noise! Its one of the all time classics and used in a twin amp set up its perfect as an amp to kick in for a thick sound. Thinking about it I gigged a 68 Silverface Princeton and a Fender tweed Champ once or twice and I thought it was a wonderful combination. Admittedly it was in a single guitar band. Doing this even meant that I could use reverbs and delays in a wet dry set up (PRRI wet, Champ Dry) too without fading into the mix. Also it was the most back friendly set up I've ever used.
Also a 12AY7 in V1 rather than an 12AX7 may affect headroom.
Long answer, it depends on your particular 5E3. I’ve had a few, original ‘59, Mission, Clark, Flynn, Gartone.
The only one I could/can gig is the Gartone. Maybe it’s the speaker, but it’s head and shoulders above every other one I’ve had. I played in a loud classic rock band with a hard hitting drummer and the the singer/band leader sometimes would ask me to turn it down.
Rob
With my high efficiency 2x12 EVM (100db) equipped boogie cab I can get a serious level of volume from my DIY amp. Mine is modded for 6L6.
Of course carting a huge mesa stack defeats the small amp benefit.
It’s all down the the music limits and volume discipline of bandmates. It can be a one trick pony.
We play classic rock and currently have 2 guitars - it wouldn`t work unmic`d here. Rock drummer, but not the loudest I`ve played with.
I also play in the house band for jam nights and the occasional pop style gig - fine here but sometimes the issue is because the volume is `off........ LOUD!` it`s too loud. I find the princeton works better.
Personally I always carry a flat sennheiser in the gig bag so if I do have a small amp it can be give a little `spread` through the pa, rather than out and out more volume.
