As above . . . Its fine for around 30 mins . . . then I get a little "white noise" at low volume but the guitar volume through the amp rises a little . . . it stops after a minute or so then its fine . . . ! ! I'm pretty sure its not the rectifier as amp hasn't blown a fuse or crapped out completely . . I've got a JJ 5751 in V1 for first gain stage on Normal, I have a Mullard 12AT7 in V2 as first stage gain for the Vib channel V3 is also a Mullard 12AT7 for the Reverb and Ive heard no pops or splashes there so I'd have thought that one was OK, V4 and V5 are both 12AX7's ( Harma Cryo's) V6 is yet another Mullard 12AT7 . . . The Power Tubes are Groove Tubes and so is the Rectifier . . Ive got some spares but not sure which one, or pair could be the most likely suspect . .
Feedback : https://www.thefretboard.co.uk/discussion/58125/
Normal channel on ZERO . . Using Vibrato Channel . . . Could it be V4 ??? Calling @ICBM :-)
It could still be any of the others except V5 - even V3, noise from the reverb driver can get back into the signal path. The best thing to do is swap out each one in turn.
One chap I spoke to suggested it could be the CAPS ( the ones in the little tin bath thingy ) as apparently thay are cheap quality ???
Any ideas anyone ??? @ICBM may I trouble you yet again :-)
Cheers @EioPago . . . . Does the power grid resistor fault case an intermittant white noise/static sound ???
Usually what happens is that one of the power tubes dies and it takes its power grid resistor with it (there is one resistor per power tube). Sometimes the resistors fail just for heavy overheating.
It's worth taking a look.
Im dropping it off next week . . . hopefully it wont be an expensive fix . . . . !
Fingers crossed :-(
