But - the Princeton sounded *far* better - really a lot bigger, clearer, fuller, more dynamic, just more of everything really. (Other than raspy midrange!)
That said a Celestion would not be my first choice, even though I like the G10 Greenback. Fender seem to have a real thing these days for trying to make their amps sound like half-baked Marshalls - not sure why. In my opinion they sound much better with 'American voiced' speakers.
I also think the amp probably has a different OT, since the original 5F1 is a 3.2-ohm output, and the Greenback is only available in 8 or 16-ohm, unless Celestion have made special ones for Fender. For what it's worth the 5F2 Princeton is also an 8-ohm output as stock - why different from the Champ, I'm not sure since they were both 5W amps with 8" speakers originally.
R2 And R3 = 100kOhm 0.5watt
D1 = 12.1v 1watt zener
mosfet = either 2SK2968 or NTE2973
pot = 1meg lin
or if there’s a standby switch stick it there instead of the standby!.
He used to use American White Oak but found that too.much of the supply was unusable.
@munckee has (or had if he's sold it now) Silver face Champ is also pretty room filling. That's old dry pine I think?
But I think I have less of a tolerance for this than some people...
Boxyness is easier to hear when you have two amps/cabs side by side, it is a function of the cab size and the speaker.
Plug your amp into a bigger cab and you will hear all the bass that the little combo cab is not capable of reproducing.
Thing with these old tweed amps is they need the bass attenuated, so the cab is a big part of the sound.
I also compared it to a Tone King Falcon 10 with similar results.
The Victoria 5112 a friend had sounded fantastic too, with a G12H-30 in the cab. So much better* than a Champ with an 8" speaker you wouldn't even think it was the same circuit.
(*Unless you specifically want that ratty blues/early rock'n'roll sound... I did, for one band, but it was far too limited for anything else.)
I much prefer the champ through a bigger cab and speaker too, but the bass can be improved a lot.
