The Imperial® Humbucker captures the airy top end, balanced midrange, tight lows, and complex overtones of the classic original P.A.F. pickups. We then improved on the design to give you a more balanced frequency response. Its medium output is in the vintage range with a hotter wound bridge pickup compared with a typical vintage set. Our unbalanced coils produce a tight bottom end that complements the pickup's fullness and causes overtones to build after each note is played. Overall, it has a fuller bridge tone and a cleaner and brighter middle position. The neck is hot enough to play on the edge of amp distortion, or you can adjust your picking pressure to achieve a cleaner or dirtier sound as desired. Made with Alnico 2 magnets in the neck and Alnico 5 magnets in the bridge that are degaussed to specific levels unique to the neck and bridge positions. Nickel Silver covers.
Avg. DC: Neck 7.6K, Bridge 8.4K
£200.00 plus £5 P&P
Please, no lowball offers. These go for £330 a set new & pretty scarce in the U.K.
