Considering the Blackstar HT5 MkII
chrisj1602chrisj1602 Frets: 3889
I live in an apartment, currently using my HX Stomp for all my electric playing and I’m a bit tired of headphones and I am hoping to get into some rehearsals soon and think I would prefer an amp behind me than all PA.
I think the HT5 Mk II could be quite useful for me; 4 voices over 2 channels, reverb, footswitch included, 0.5w setting for playing at apartment level but still has headphone out for the evening, 5w hopefully enough for rehearsal rooms but if not I can send to the PA while still having my amp volume (same could be done for gigs), USB recording also a bonus. Effects loop so I could use my HX Stomp for effects in the loop or even use the modelling into the effects return...
In theory it seems to be a great amp for my needs but I can’t try one out locally.  Anyone on here own one or tried one out?
  • GrumpyrockerGrumpyrocker Frets: 4118
    Yes I own the head version. It's a great amp. The headphone out is particularly good as the reverb is stereo which makes a big difference.
    It's also bloody loud in 5W mode, but the volume pot taper is good. I tend to play it more on 5W mode more than lower power mode - but I live in a detached house. Low power mode can go very quiet, so you should have no problems there.
    Effects loop sounds good. And yes I've used it for modelling power-amp in use and it works well for that too.
    Sometimes I find the dirt channel a little dark, but I've a cheap EQ pedal in the loop that sorts that out.
  • S56035S56035 Frets: 1104
    Hi Chris.  Where are you based?  I was going to put my HT5 MKII Combo in the classifieds soon no we can start moving around more.  If you're near you're welcome to give it a go and possibly buy it :-)  I'm based in Luton.
  • BeardyAndyBeardyAndy Frets: 716
    edited May 2021
    I've owned the HT1 and HT20 head and combo (and an Artisan 15!) My only worry would be if the HT5 will get over a drummer in rehearsal? Depends what you're playing I guess but there wont be much headroom left to play with.
    Something like an Orange Rocker 15 will give you a proper valve amp that you can use at bedroom levels and small gigs.
  • monquixotemonquixote Frets: 17485
    I've had the MK1 HT20 and gigged with people that used the HT40 and HT100 and the DSL40CR I recently bought is a much better amp.
    It has a very good master volume and a 20 watt mode so it's very easy to use at home. It's also got MIDI so you can control the 4 channels and 2 master volumes from the HX Stomp for live use.
    I know the MKII is meant to be a big improvement so this might not be relevant.
  • munckeemunckee Frets: 12253
    What about a laney cub 12r, they are 15 watts with a 1 watt input?
  • SupportactSupportact Frets: 895
    I had the earlier version (combo, no reverb) and thought it was great. Sold it to get a bigger amp, but would have one again. Surprisingly loud. I used an extension can with mine.
  • chrisj1602chrisj1602 Frets: 3889
    I’m in Stockport so a bit far out unfortunately.
    Might have a look at the Rocker 15, loved my old Rocker 30.
    Thanks all for the comments and suggestions, given me some more reading to do!
    Oh well.  It's certainly a good amp for home.  As someone else said the 0.1W mode is usable but the 5W mode has good enough adjustment in the volume to not need it.
    edited May 2021
    I've owned the original HT5 head and have the Mk2. The MK2 is definitely a much better amp. Both in terms of sounds and features.
    I do also own a Laney Cub 12R. That's a fabulous sounding amp too. But in terms of build quality and reliability the HT5 is likely a better bet. Also the Laney doesn't have a headphone output or any kind of USB/XLR/Line Out options for recording or going into a PA.
    I've got a Mk 1 Boss Katana 100 combo too and it sounds amazing. However I think the headphone out sounds better on the HT5 Mk2.
  • hollywoodroxhollywoodrox Frets: 4079
    edited May 2021
    What about the DSL5CR ? Or DSL20 CR ? Seem to be highly thought of and it’s got the magic name . Expecting ICBM to appear soon
    Sold a Tiny Terror because my old Laney VC30 did the job, then the Laney died and I replaced it with the HT20. It's great for £200 but I miss that Orange tone!
    The other option would be to just get a 1x12 cab and a power amp.
    I did that with my Helix.
    If you are using a real guitar cab it really does sound like a real amp.
    That sounds like it’s worth looking at, thanks.
  • CleckoClecko Frets: 295
    ^ 100% this! I use my Helix into a Seymour Duncan power amp into a cab (well, the speakers of a combo with the amp disconnected).
    I had the first HT5 head, and while I know the MKII is supposed to be a lot better, I can't imagine for a moment that it's as good as the Helix>poweramp>cab approach, which sounds fantastic.
  • I’ve got an ht5 mk1 I like it. It’s surprisingly loud at max volume. Feels like much more than 5w more like 15/20w solid state amp.
