GS-1 Transformation
tanihhiavlttanihhiavlt Frets: 659
edited May 2021 in Making & Modding
My name is Frank and I am a compulsive fettler/modder
I have destroyed several very cheap guitars, spent lots of money assembling mediocre guitars (except the finishes by SRC Relics that are sublime) and reduced the value of several expensive guitars - I am unrepentant. I do this to distract from practising guitar - which I am trying to address.
This is my GS-1 Singlecut - already Stuart Robson has done an excellent job of making it a double-cut... I simply lack the immense talent and care required to do such a good job (as the side jack shows - fitted to accommodate a varitone).
So I want a neck pickup, maybe a second set of volume and tone controls, I like some settings on the varitone but there isn't space for a toggle and a varitone...
I've decided the pickups are Zebra style, exactly which can be decided later... sithee Tesla Sharks
So originally I'd wanted to have the neck pickup the 19.6mm from the fretboard end seen on SGs but that would mean a new scratchplate and I'd quite like to be able to return it to a neck only pickup.
The big thing about this post (for me) is it's a social contract - this isn't going to get in the way of me practising! I'll be resetting the Stayfocusd app on Chrome to 9am so I can upload that days photos
Which I usually do 8am - 8:30 prior to work - before I'm too knackered and braindead or the kids are in bed (excepting the eldest who's on U.S-time for gaming purposes)
In the next post I'll spell out my terrible plans for the guitar and also share the shots of Stuarts excellent work (admit it, if I hadn't told you it used to be a single cut, you'd never have known!)
  • WezVWezV Frets: 16735
    that position for the pickup should be fine.  The join is different enough from an SG, it shouldn't weaken it too much
    Loads of room for more controls, just increase the cavity whilst doing the other mods
  • tanihhiavlttanihhiavlt Frets: 659
    Cheers Wez, that's appreciated :)
    I'm thinking I'll look at dual concentric pots first - see if I actually need the the configurations - I think I've designed a 6-way setting to replace the varitone (I'll keep the BB King setting on push-pull), so I should get
    Neck Humbucker
    Neck Single
    Neck Humbucker + Bridge Single
    Both Humbuckers
    Bridge Single
    Bridge Humbucker
  • ICBMICBM Frets: 72486
    My advice would be to forget the extra volume and tone controls - they’re really not useful, for me - and replace the neck humbucker/bridge single setting with both singles - mixing very different pickup outputs doesn’t really work well in my experience. (The *lower* output pickup dominates, surprisingly.)
  • abw1989abw1989 Frets: 639
    Great pick up choice by the way, I really like those Tesla Sharks, not just a Slash one trick pony set.
    Welp the Gordon Smith I just hoisted out of there is the size and weight of an output transformer!... I'll probably hook up the bridge pick-up in advance of the 6pdt rotary arriving, to see what it sounds like - some people swear by the Gordon Smith pickups - it's certainly a unique design
    I am excited for the Tesla Sharks - cos I did like the clean tones I heard people get on them :)
    The prequel: All Stuart Robson's fine work:
    I think you'd need balls of steel to do this work - and the finished woodwork is amazing - you'd never tell!
    As for the finish, Stuart advised getting it finished but I'm happy enough with his match job for now :)
    The journey so far:
    I'm entertaining using a 3 toggle switch and maybe swearing off the push-pull all together (unheard of for me)
    Lovely clean tones from the Tesla Sharks and from a Pignose too!
    All that's left is the jack socket on the side after that :)
