Hi all
I have an acoustic guitar which sounds adequate although a couple of things I'd like to get sorted. It's a Taylor Big Baby, it has no electrics built in so to amplify it I require to use a pickup. I bought a Seymour Duncan Woody ages ago which I normally use, lord knows why I bought the Single Coil version.
When I use it, there seems to be noise, like high pitched hissing. I think that's best way to describe it. I think somebody mentioned before it could be the single coil, but also that the output volume of these is really low so you have to turn it up way high and then you get noise.
Anyway - I wondered if there were any options to improve this, or whether I just need to bin it and but something better? It's a budget guitar and it's not an amazing instrument, so I'm trying to just get the best I can with a low budget to make it useable and not have to worry too much about it.
Would some kind of preamp or acoustic sim pedal work to provide a better cleaner level?
Do I just need a different pickup?
I'm not very knowledgeable about acoustic guitars but seem to have some natural ability for folky picking and singing so tend to get asked to play that.
Thanks all
Matt
Another pickup is very much recommended rather than throwing money at adding things like a preamp.
If so what is your budget? If you buy a good sound hole pickup you can keep using it if/when you change guitars later.
I would replace the pickup first though with an under saddle piezo.
The hiss might be coming from the amp having to be turned up too high to get a decent signal level, of from the pickup picking up something like switch-mode power supply (eg computer or phone charger) noise, in which case being able to boost the mids but cut the high treble could be useful.
I find a 'seagull' or 'twin peaks' shape on a graphic EQ works well with an acoustic guitar and a magnetic pickup usually. (Deep bass and high treble down, low mids and high mids up, mid mids down a bit.)
*Only* if you plan to use a really good outboard preamp as well, which is going to put the cost up a lot. A piezo on its own sounds far worse even than a bad magnetic. (Albeit louder.)
I have had the dubious pleasure of dismantling an SD Woody. The resin sealant took a fair bit of dislodging. Inside, the bobbin resembles half of a Hot Stack For Stratocaster. It is thoroughly screened in copper foil.
The top of the wooden cover is approximately 3mm thick. This and the soundhole fastening slots result in the pickup coil sitting rather a long way from the vibrating strings. Consequently, the signal is not strong.
Yes and no, in that order.
A dedicated pre-amp processor for acoustic guitar should help by adding compression and multi-band equalisation.
Possibly.
Based on the experience of a local shop proprietor and guitar tech, I would try this quick experiment. Slacken off the strings on the Baby Taylor and see how far inside it you can get your forearm.
Seriously!
If you cannot make firm fingertip contact with the pointy ends of the string pegs and the strap button, you are going to struggle with any internal installation, be it UST, K&K Mini or my beloved LR Baggs Lyric system.
That leaves soundhole pickups. The serious ones will cost at least half of the purchase price of the guitar itself.
Similarly, the LR Baggs Venue pedal will be several hundred Pounds.
Are there any pickups around the cost of the Woody that would be adequate, doesn't need to be great as neither my playing nor my vocals are great either.
The kind of setup I get to play at are general amateur events similar to open mics I guess, that's the kind of thing I'm useful at, basically background music. I'm hopefully playing at a couple of local arts fest type things this summer, Covid allowing. Itll just be me, my Acoustic, a mix, into either my own little pa speaker (working on that) or a communal pa speaker.
I do play with quite a light touch and quite quietly, I don't bash out strumming chords, so I suppose that doesn't help the volume thing.
In fact here I am on a live stream version of the one arts fest in hopefully playing again this year, obviously had to go online last year
soundcloud.com/thecolourbox-1
IMO, the fact that you have posted this question suggests that you care about how you sound in live public performance situations.
I suggest searching YouTube for LR Baggs M1 v. M80 comparison reviews.
You really need to stop doing this, Matt. Don't tell audiences that you're crap before they have even heard you perform. At the very least, allow audiences to decide for themselves.
Confidence and sincerity. Once you can fake those, you've got it made.
My confidence level is proportionate to my skill level I am satisfied I can generally sound adequate in the right scenario, so I only need stuff to sound adequate rather than amazing as there's not likely to be much gained or me trying to sound amazing rather than adequate. Especially with the money involved, it's lipstick on a pig while I still use the Big Baby. In my experience, unless you're using mics and nice acoustics, they will always sound a bit crap in the kinds of setups I play at. The main thing I care about is how it sounds for me rather than the audience, and I'm seemingly over-sensitive to pickup noise in general so getting something that eradicates that is mainly what I'm after.
I wouldn't get much on trade in for the Big Baby I reckon, but I'll have a lot to see what is out there with piezos instead if the NS2 into electric guitar amp doesn't tick the box (and also mull over a PM offer I've received for a different pickup).
Cheers all
Edit, Oh I do also have a few mics that i could perhaps consider setting up on a stand I guess - I've an SM58 alike, SM57 alike, a condenser and a TC Helion MP75. The condenser I guess is not worth the hassle for this kind of set up but the others may be able to build up an array of sorts I suppose
If your BBT has the screwed-in strap pin, it should be easy to perform a DIY installation of either a soundhole pickup or devices such as the K&K Pure Mini, LR Baggs i-Beam or Lyric.
A pre-owned LR Baggs M1 ought to be available in the £100-150 region. Fishman has the Black Stack. DiMarzio has the Black Angel series. Some of these may even be designed to work through electric guitar amplification.
If I remember correctly I had to use two EQ plugins in series to get rid of the noise, and even then had to keep the level very low in the overall mix hence why it's very quiet compared to my voice. I don't usually play it without a capo as the B string annoys me - in tune open out of tune fretted, or vice versa. If I need to play using "open shapes" I either have to arrange it so I don't use the open B string in my shapes, or tune it down a note and capo it at first fret. Perhaps that provides info on the nut, I don't know. I once tried to get Hobgoblin to take it in and sort out that issue and lower the action a bit but they decided to patronise me for my lack of knowledge and told me it would take several weeks to get it back so I just left it.
I've just read the instructions for the ibeam...not a chance I'd manage that kind of thing. If I added up the cost of the pickup, and installation by somebody, I might as well just flog this thing and get something else which already has piezos built in, and might not have the silly B string issue or high action. I'd prefer a Telecoustic but they are so quiet due to the small body and the one I had the preamp failed a few times on me.
Not to worry. Hopefully the Boss buffer plus electric guitar amp combo succeeds enough, nobody is going to care anyway I suspect
Passive DIs do work very well with active pickups though - they often sound more natural than adding another active stage into the chain.
I interpret this to mean that the Hobgoblin repair department was so busy that jobs were queueing for their turn on the work bench.
Unless the counter staff lifted you by your lapels and said, "now, listen here, pussycat" in the style of a Tom & Jerry cartoon, you were not being patronised or slighted.
