Shuker 5-string Jazz Ziricote Bass
£1600
From the custom shop wizz that is Jon Shuker - one of the best builders in the world.
Having a big clear out to raise funds
Upgraded Ziricote top
Premium light-weight alder body
Hard rock birds-eye maple neck and board (7-piece neck)
Set neck
Matching headstock
34" scale
Brass nut
Seymour Duncan pups and 3-band active pre-amp circuit (I can't remember if its an East or SD preamp - sounds stunning though)
18mm string spacing
8.9lbs on my scales
Active/passive
Killswitch - not sure why...
Passive tone control, stacked bass/treble, mid, balance and volume
Shuker embossed Hiscox case
https://imgur.com/IraRgPZ
https://imgur.com/3OSpLA5
https://imgur.com/WvvFdMX
https://imgur.com/jDNv094
https://imgur.com/2OBogeD
https://imgur.com/n1RKlE5
https://imgur.com/5KHPZS0
https://imgur.com/pENx4nq
https://imgur.com/GAbxAwi
  • FunkfingersFunkfingers Frets: 14459
    I associate those matt black control knobs with Seymour Duncan STC onboard pre-amp/EQ systems.
    A shot of the controls in their cavity would soon confirm what brand(s) you have.
  • HongKongJonHongKongJon Frets: 36
    Truth. I was at work that's all and not able to get to the bass for the check. Will update very soon. I'm 99% sure SD
