cheap fingerstyle guitar
Paul_CPaul_C Frets: 7913
any suggestions for something with a little more room than an APX700 for fingerstyle playing ?
  • FretwiredFretwired Frets: 24602
    Try Crafter or Guild. They make guitars with a wider nut/fretboard for finger picking.
  • Paul_CPaul_C Frets: 7913
    edited August 2014
    Paul_C said:
    I assumed you were after a steel strung guitar .. a classical guitar will meet your needs albeit they are nylon strung. For the money Yamaha are a good bet. I started life playing classical guitar ... a long time ago mind.
    edited August 2014
    I was/am after a steel-strung guitar, the " I'm pondering one of these as an option too " was meant to suggest that the nylon might work as an alternative.
  • IanSavageIanSavage Frets: 1319
    The Vintage Gordon Giltrap signature has quite a wide string spacing. Or you could get Mark D Philips to knock you something up from a knackered 12-string.
    I could probably manage something along those lines myself ;)
  • What an excellent suggestion Ian, and good this thread happened to catch my eye tonight!
    191253236644
    That ebay item number is one option, and there is a somewhat cheaper one there as well.
    Worth a look?
    Mark.................
    edited August 2014
    please don't pollute my thread with your abominations.
  • Aha yes, yet another person on here who knows everything about my guitars without ever seeing one... I must teach myself how to know all there is to know about any guitar without ever needing to look at it close up... I guess it is all about just needing to believe everything anyone on here tells you to believe?
    ps.
    Is your thread really so delicate?
  • LixartoLixarto Frets: 1618
    Paul makes real guitars.
    He does .. I bought one and still play it ... :-)
    He did some excellent work on my main Tele a few years ago.
    I trust Paul implicitly; others, less so.
  • Depends on how you define cheap.
    The Vintage range has a few lovely wee parlour models which make great finger pickers- V880 springs to mind (can be had for less than £100 second hand) higher up the range I have a Brett 12, but played the 6 a LOT in the shop- I believe it has the same nut width as the 12, but with half the strings. It's LOVELY. (£300ish new, don't know about secondhand- they don't come up often).
  • xSkarloeyxSkarloey Frets: 2962
    Can't comment on the neck as I haven't tried one yet, but the Sigma 000m15 is on my to try list. All mahogany made in China to standard Martin 000 dimensions. I think it's the Martin Carthy influence but I always have 000 size guitars in my mind as benchmark fingerstyle guitars.
