FS Various bits and bobs (Pedalboard, Pedals, Power Supply, Patch bay, Hum destroyer)
Pedaltrain Nano. Used briefly at home but now surplus to requirements. In good condition complete with soft case. Comes in original box. £30 posted. SOLD
Joyo American sound. Designed to emulate a fender amp. I bought it as a backup to my valve amp years ago, in case the amp went down then I could just plug my board into this and plug direct into the mixing board. It sounds good enough in a pinch and would get you through a gig no probs. It’s been lurking at the back of a drawer for years. The box is a bit battered but the pedal itself is in good condition and works perfectly.
£25 posted. SOLD
Joyo Roll Boost. A straight up clean boost which does exactly what it’s supposed to. Again this has been sat in a drawer for a few years. It’s in good condition and comes in the box. There is Velcro on the base.
£25 posted.
Lazy Bear effects 2 way patch bay. Very handy this if running a tight pedalboard or you just need a compact patch bay. It’s a 2 in 2 out affair. It has pedal tape on the base.
£20 posted.
Nordell Audio Power Core Pedalboard power supply. Bought when I was running a bigger board and it worked great. Including powering a Strymon Iridium which had a high current draw and about 6 other pedals. It worked great and it was silent. Comes with the power adapter and all the power cables. No box with this.
£25 posted. SOLD
Behringer Hum Destroyer. I bought this when I was running a Fractal FM3 in 4 cable method and I was getting a bit of noise. This little box killed it so it’s a handy thing to have around. No box with this. £15 posted.
