FS: Rockcase by Warwick RC 23140 B - pedalboard with built-in PSU, looper & 5 guitar stand
delgwapodelgwapo Frets: 4
edited August 2014 in FX £
For sale: Rockcase by Warwick RC 23140 B Pedal Board
Heavily gigged with the usual scratches etc. but well-built and in good working order. Selling it as I'm not gigging for the foreseeable future.
It has a built in power supply with 5 x 9v and 1 x 12v power sockets (unfortunately I only have 4 x 2.1mm to 3.5mm polarity-reversible leads and 1 x 3.5 to 3.5mm (ProCo, EHX) but I will chuck in a 2.1mm daisy chain), two parallel loops (check out the possibilities here) and the lid turns into a pop up guitar stand that holds 5 instruments. It's all heavy duty with four large butterfly latches holding everything together.
These don't come up that often and I used to get loads of enquiries about it from other bands so this hopefully this won't be available for long! Full tech spec below photos (the pedals pictured aren't mine, just googled it to give you a rough idea of size).
£85 collected from Oxford or £95 delivered
  • Features:
    ·         flight case with integrated gig board and guitar stand for 5 instruments
    ·         8 mm / 0.31" strong plywood, covered with black PVC
    ·         velvet cloths covering for the butterfly-locks to protect the instrument bodies
    ·         bottom covered with Velcro
    ·         removable, padded lid
    ·         stand with pin lock system for a fast and easy assembly
    ·         nickel-plated steel spring handle with transparent PVC covering
    ·         4 chrome-plated butterfly-locks
    ·         chrome-plated ball corners, aluminium edges
    ·         usable area for effect pedals: 72 cm x 34 cm / 28.35" x 13.38"
    ·         ground level: 5.2 cm / 2.04" -
    ·         size: 74.0 x 44.0 x 19.4 cm / 29.13" x 17.32" x 7.63"
    ·         14kg
  • Technical Specifications :
    ·         internal power supply max. 400 mA
    ·         5 x 9V DC stabilised
    ·         1 x 12V DC stabilised
    ·         2 signal loops wired in parallel (1/4" jacks) for various setup possibilities
  • Bump!
  • Bump for offers - open to pedal trades too.
  • monofinmonofin Frets: 1118
    What's the tape by the power inlet? Is that covering some damage?
  • Ah no, the socket felt a bit loose once but I glued it back and added the tape for good measure. The socket itself is fine now, no movement, I was just being paranoid!
    Thanks - pm'd
  • Sold!
