Ultimately I want to be able to play slide on any guitar, but I'm a ham-fisted lump and getting a light enough touch to play on my guitars with a normal action is proving to be FUCKING IMPOSSIBLE and very frustrating :-D
Also, will learning to play slide on a guitar with a high action make it more difficult to then transfer to a regular action? Am I better to just suck it up, persevere with my regular guitar and learn to be gentle?
Having said that , the correct setup should be OK . But if it is on the low side , that might make slide playing harder .
You might not be holding the slide flat across the strings . If it's lifting up at one side , some strings will buzz and pressing harder will not fix it. High action means you will need to press harder to fret the strings . Some pople have strong fingers , but not everybody. If your totally new to slide . Have a look at justinguitar.com . He has a , the slide guitar basics and it's for free.
