3) Rotate the saddle anti-clockwise half a turn.
5) Clamp the second grub screw in the vice. Hopefully, you have the clearance to rotate the saddle anti-clockwise in a continuous circle.
If none of that works then get a new saddle.
If that's the case, the only remedy is to drill them out. What you should find is that when the drill gets some way into the screw, it creates enough friction to grip the screw and drive it out rather than cutting further.
I may try and cut a slot in the base of the adjuster and try screwing it out but not too sure how to go about it, I was hoping that the allen key adjuster was reversible and could access it from the bottom.
It's the two adjusters one on the E and the other on the A string .
If adjusted in accordance with Wilkinson instructions, the two E saddles should sit flush on the vibrato baseplate. Hence, no grub screws required.
The distance by which the A, D, G and B saddle grub screws protrude is a direct reflection of the fingerboard radius.
I prefer a small amount of grub screw protruding even on the high E, I find the saddle tends to slip more if there's none at all.
I've just tried drilling the adjusters out but 2 broken drill bits later it hasn't done much.
Just found this online and maybe the best option, it says it's for a vs50 bridge but hopefully they'll do the job.
https://guitarpartscenter.eu/en_US/p/FRAMUSWilkinson-VS50-single-bridge-saddle-GD/14031
@AK99
. Would it be best to to use them for the two E strings and adjust the other saddles in line with them .
Would the extra mass much off a difference to the tone?
https://ibb.co/Ky8yXvP
Also heat and cool the grub a few times.
Probably not.
My advice would be to remove the locking cam from the backplate and set the arm high enough that it can't foul the plate at all. They're an absolute nightmare to make work properly and reliably.
