Personally, I'd leave the headstock as is.
Cost! Who knows?, not much as its pretty easy to do and your neck is unfinished, so there is none to damage in the process
You can find headstock templates online that you can print off, cut it out stick it to the headstock you want to mod with pritt stick after lining up the tuner holes, cut the waste away and sand to shape, pretty easy….
But I think I'd like it to look like a tele headstock :-)
• Youtube - https://www.youtube.com/@Goldeneraguitars
