Actuator
An actuator is installed on the inner surface of the guitar back vibrates in response to the vibrations of the strings. The vibrations of the actuator are then conveyed to the body of the guitar and to the air in and around the guitar body, generating authentic reverb and chorus sounds from inside the body.
Simple Controls
Three simple knobs let you adjust the degree of effect applied and the line-out volume level. Additionally, keeping the controls small minimizes the area of the holes in the body material, reducing acoustic sound loss
New Battery Box
The battery box is integrated into the end-pin jack. This requires fewer holes in the body, thus reducing acoustic sound loss. Connect the cable from the jack to a PA or amp to use as an Electro-Acoustic Guitar.
Designed to Provide Superb Acoustic Guitar Sound
The body is an all-solid guitar based on the L-series. A modified non-scalloped bracing design enhances the low end with retaining the bright tone. Treating the tops with Yamaha’s exclusive A.R.E. process gives the instrument a rich, vintage quality tone.
£675 collection preferred from Aylesbury/Bicester area or Chesham during work hours. Happy to discuss possible delivery
