Preferably, a drop with the string out of the slot, then tune up and let harden.
If it is low, it will rattle on an open chord, which is a bit different to a buzz from a worn slot or bad angle.
It usually affects the plain stings more, and if it is low there are other fixes (baking soda) which will mean the slot needs
re cutting.
If you have a tiny gap, check relief and action.
Instagram
