I'm thinking of building an amp one day from a donor amp etc and put it into another cab and speakers etc. However, everyone has their own preferred speaker preference in different amp combinations etc. However, how do you know which? I mean some of these speakers go for around £300. So is it an expensive trial and error scenario or do you send them back if you don't like them etc?
Also if the donor amp came only with a one speaker output and you wanted to have it go into a 2 x speaker output is it complicated to put the extra wires to the amp etc? I am a novice by the way guys
Bandcamp
Spotify, Apple et al
You try one of those and if it's not quite right you will know in what way, which should make the right final choice quite easy. Only after that you might want to try something more unusual if the mood/budget takes you.
You can easily add another speaker, but you need to know the rules for working out the total load impedance, which is not the same as that of each speaker, and make sure the amp can be safely run like that.
Bandcamp
Bandcamp
I don't understand the PM system here?!!!
Hotpicks' PM me I may be able to help.
Dave.
Bandcamp
No substitute for trying the thing, but you can definitely narrow it down as ICBM says.
